Can Some One Please Help.
I Have A 2000 Au2 Which Seems To Be Going Through Batteries.3 In The Last 6 Months. Can Someone Offer Help? |
it is most likely the alternator ( overcharging and cooking the battery ) with the engine running and a digital multimeter check the voltage should be 13.8 to 14 volts
#3 | |||
Karasu
My Curent Battery Has Lasted Nearly 2 Month's.
Checked The Battery While Running And Was Indicating 14.4 Volts Yesterday. Today Indicated 14.05 Volts.the Battery I Purchased Has A Maximum Charging Voltage Of 14.8v. |
Is It A Simply Replacing The Regulator
yes thats right replace the reg and you should be ok also if you are geting those reading at idle you might find it higher with a few revs onboard if the reg is cactus
#7 | |||
Karasu
If you use the dah diagnostic mode as well ... you can monitor voltage while driving as well as it is display digitally in your odomoeter area.
