Old 06-05-2007, 06:30 PM   #1
melbzetec
Old enough to know better
melbzetec's Avatar
Default She won't start
Went to start the car late this afternoon...won't start.
Drove back from the city at 3pm...no problems.
But at 5pm,engine won't even turnover, just a click,click,click sound.
I'm quessing starter motor or battery. Stereo, locks etc however all work.
I clutch started it. Ran smoothly.
Any suggestions? Off to the Auto electrician in the morning I think
Old 06-05-2007, 07:09 PM   #2
photn
AFF Post NAZI
photn's Avatar
could be your starter motor.... or you batt just JUST didnt have enough...
Old 06-05-2007, 08:33 PM   #3
twistedfirey
sounds like a starter solonoid... try a few gentle taps with a piece of timber, has worked for cars I've had in the past... if it doesn't work check the battery terminals are clean, may have enough power for windows etc but low on cranking amps, good luck.
twistedfirey is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 09:23 PM   #4
cArSiK
battery for sure,
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 10:33 PM   #5
zetec
Zoom Zoom
zetec's Avatar
Your car was telling you it SHOULD have gone on the cruise!!! My guess is Ford Racing has liberated so much horsepower that it just has trouble even starting!!!
Honestly, as mentioned above, battery is suspect number 1, can be easily tested by your local auto mechanic with a battery tester very quickly. Haven't heard of an LR Focus starter motor failing yet...
2012 Mazda3 MPS
Old 06-05-2007, 10:42 PM   #6
Martyvan
Martyvan's Avatar
If all the electrics are still working ok, and it ran ok with a clutch start, I would imagine that a starter motor is at fault...
just get it checked, im sure it will only delay any future mods... not eat into the home mortgage... hehe
Martyvan is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 10:50 PM   #7
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
Check to see if the battery terminals are corroded or loose first before you do anything and then;
* Jump Start the car and If it starts, then you've got a battery problem.
If it still doesn't start but still makes repetitive ticking noise, then you've either got a low battery on your jump starter or your starter solenoid has had it.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2007, 08:26 AM   #8
BlackLS
Like extremist said check out the terminals first, clean up with small wire brush and put vasoline on the terminals to prevent corroding. Also check if the battery electrolite levels are above the plates.
If both are good, grab your multimeter and see how it goes when cranking the car. It should drop down to about 8 or 9 volts whilst cranking. If it goes down to 1-3v battery has no charge. If the battery is only new you may have problems with alternator not charging the battery properly.
If battery and charging is both verified to be good, then you check out the starter.
Old 07-05-2007, 08:38 AM   #9
melbzetec
melbzetec's Avatar
Thanks for your help guys.
Yes terminals are fine, but took them both off, cleaned and reconnected.
(ps I also checked out the fuel cutoff valve. No issue)
Multimeter is not something I have...so it's off at the Auto Electrician this morning.... just waiting for the call.
Old 07-05-2007, 12:25 PM   #10
eXtremist
eXtremist's Avatar
Try jump starting the car before you take it to a pro.
Old 07-05-2007, 01:23 PM   #11
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
No RACV or anything like that ?
They can come in handy just for their tools at times hehe
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2007, 03:02 PM   #12
melbzetec
melbzetec's Avatar
In the past my cars have been covered by rodaside assist, and I have let the RACV membership lapse. They wanted $188 to join me up and come and have a look.I'll join up again this week
Anyway the Auto Elec just rang. A weird one but not serious.
Apparently the earth cable to the engine has broken, and the current ended up going through a more narrow gauge wire and eventually burnt out. All replaced...$88.
How the hell the earth cable got broken (polishing the engine too much perhaps??????!!!!LOL)
I'll find out more when I pick it up
Old 07-05-2007, 03:15 PM   #13
Martyvan
Martyvan's Avatar
I just thought thats incredible you got a auto electrician on a public holiday, but then realised its only a day off in Qld today!
Interesting fix, but awesome that he was able to fix it soo cheaply..!
Old 07-05-2007, 03:34 PM   #14
melbzetec
melbzetec's Avatar
What's the excuse for a public holiday in Qld? Russ Hinze Memorial Day or something?
Old 07-05-2007, 04:14 PM   #15
Martyvan
Martyvan's Avatar
Think its labour day, believe you guys have the day off in October?
Was thinking it was the Sir Joh's stutter appreciation day...
Old 07-05-2007, 04:34 PM   #16
Marlene
Labour Day.
Marlene is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 09:11 AM   #17
photn
AFF Post NAZI
photn's Avatar
sorry to hijack the thread steve, but what the hell is with that... shouldnt labour day be held on the same day all around australia... did queensland just decide. a feck it... well do it when we can be bothered...... ????
Old 08-05-2007, 06:31 PM   #18
Mick K.
Mick K.'s Avatar
I (a Queenslander) always associated "Labour Day" and "May Day" as being pretty similar, so it always made sense to me to have the public holiday near the start of May. Given that the 2nd half of the year is pretty much devoid of public hols in Qld, I wouldn't mind it being moved later. Actually why not just throw an extra one in sometime - I'm sure they can find an excuse.
MK
Mick K. is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 07:42 PM   #19
Martyvan
Martyvan's Avatar
I associate between Easter & June long weekend with the best time of year to have annual leave. AS there are loads of public holidays.... can get an extra weeks leave for the time ;)
Its over 17 weeks though between the Exhibition show day, and Christmas, so its a looooooooong time between drinks there....
