Old 30-03-2007, 06:50 PM   #1
jono26
Default filter box
help i just put an air filter on my car and when i took my standard air box off there was 1 black line pluged in the bottom of the air box filter. what is this? does any one know? trying to post a pic but cant. sorry
jono26 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2007, 07:00 PM   #2
FRA
Mr Focus
FRA's Avatar
At the top right of the black engine cover there is a small hole.
Some models had 2 small black line pluges
You might have to do some mods to your air intake
Some pic would be good to see what we're looking @ here
My 2003 sedan has 1 small black line pluges to where our 2004 hatch has 2 small black line pluges
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2007, 07:05 PM   #3
photn
AFF Post NAZI
photn's Avatar
it should be your rocker cover air breather/filter
if you go to supercheap or autobarn and get them to have a look they should comfirm it. im pretty sure it is. the aftermarket filters for it are about 15bucks
Old 30-03-2007, 07:14 PM   #4
jono26
more help please
Old 30-03-2007, 07:26 PM   #5
FRA
Mr Focus
FRA's Avatar
Who and where did you get this air intake from?
Should of had more info on how to do this.
Is this a new filter or a new air intake system?
Old 30-03-2007, 07:29 PM   #6
jono26
its a pod filter. itook the standard factory one out and underneath it has 1 black line going into the stock filter box. i uncliped it. what does it do?
Old 30-03-2007, 07:33 PM   #7
FRA
Mr Focus
FRA's Avatar
It should go into your new pod filter and go's into your engine cover.
Where did you buy this?
Old 30-03-2007, 07:34 PM   #8
jono26
autobarn. i must have to modifiy it a little i think.
Old 30-03-2007, 07:59 PM   #9
FRA
Mr Focus
FRA's Avatar
Is this the type of air pod filter?
http://www.cardomain.com/ride/2325994/4
Old 30-03-2007, 08:07 PM   #10
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
Try to help yourself by giving us some more information, rather then just saying more help please,.
There are stckies in the Support Forums, on how to post pics
http://www.fordforums.com.au/showthread.php?t=20569
A little help on your own part will go a long way
Chris
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2007, 08:20 PM   #11
FRA
Mr Focus
FRA's Avatar
Theres a few ways he has gone about this
1) just a new air filter.
2) removed the stock air box and put on a new air pod for around $30.
3) new whole air intake system.
Until I know more, I'm not going to say anything.
Old 31-03-2007, 12:47 AM   #12
jono26
problem solved
Old 31-03-2007, 02:33 AM   #13
BlackLS
The line is a vacuum line that goes into the rocker cover.
Old 02-04-2007, 08:40 AM   #14
FRA
Mr Focus
FRA's Avatar
I bought myself a Drift mini urethane air breather yesterday and gotta tell ya it made a bit more of a difference. From 3000 rpm to 6000 rpm it was a more smoother run in the rpm.
Gave it a bit more grunt as well.
Also put back in the bottom of my stock air box intake system.
All I need now is a Mustang 70mm throttle body and Zetec intake manifold for max air intake performance. ahhh...sweet...lol
