Virtuous Bogan (TM)
![]() Join Date: Jan 2005
Hey guys.
Just wondering if you could price your cams individualy. I dont plan to get the whole kit, and my car will be stock other than a cam, headers and the exhaust. Car is in my sig. What would you recommend? I have no idea about prices but know how much roughly I want to spend. Dev1 - $ Dev2 - $ Dev3 - $ Dev3HL - $ Dev4 - $ Dev5 - $ I woukd think alot of other people would be interested aswell. thanks.
![]() Join Date: Dec 2004
Dev 1 doesnt have a cam, all the other cams are $490 regardless of Dev kit.
Its all on their website.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
Virtuous Bogan (TM)
I know the kits are on there website, but I didn't see the cams alone.
$490 hey..........
Virtuous Bogan (TM)
Ah sorry didn't open the pdf...thanks guys
Although another quick question, what does their CAI consist of for a EA-ED? Anyone have any pics?
download the PDF version, it breaks up all the prices.
Virtuous Bogan (TM)
So what would people recommend for my car? Im not going all out, just want something that gives good driveability and some more balls. Do you need venier gear with all of this cams?
#8 | |||
I would suggest talking to them as often a bit of a mix and match is possible too. Sometimes this can be a better solution too.
#9 | |||
Virtuous Bogan (TM)
#10 | |||
Best thing to do is give Jim or Brenden a call and talk to them about what you want. They will help far more than I can.
#11 | |||
RIP...
I'd recommend the DEV3 cam in your case, doesn't require valve springs or any additional headwork, and gives a very handy increase in power. Rick.
. Oval Everywhere... |
#12 | ||||
RIP...
I would use a DEV3 or DEV3HL. Quote:
Rick.
#13 | |||
Your cam must have been dialed in REALLY bad. I had my car dyno'ed with the cam angle adjusted over a 6 degree range and there is bugger all difference in peak power. Also when the peak power was lower, the mid range was stronger by roughly the same amount.
I have run a regrind cam and billet gound cam and both were spot on the grinders specs with the stock cam gear. Maybe I am just lucky.
#14 | ||||
RIP...
Advanced cams still have plenty (more actually) midrange urge, but tend to taper off at high revs where the engine isn't used as much. Retarded cams feel sluggish down low and seem to take forever to reach there peak. This is the reason many cammed engines feel worse than standard. As I said, it's mandatory to use a vernier gear. Quote:
Rick.
#15 | ||
TL40 Wagon?
Yes I have fiddled with the timing of my dev3hl cam almost as many times as useless has fiddled with his lifters and I will 100% back up the need for a vernier and timing the cam in carefully (including marking up TDC yourself not just accepting the factory got it right) to the cam grinders spec.
I tried all sorts of settings with the dev3hl and guess what Jim got it right. retard it up and it was a real dog in the md range but almost felt like turbo lag when at about 3800 rpm it would go nuts. Advance it up and its nice and mild mannered but felt a bit breathless sort of like a stock cam! I would bet advancing and retarding the cam just changes the shape of the power curve about while giving the same peak output. |
#16 | |||
lol - maybe its just the JMM cams that need the cam gear (j/k)
if cam grinders cant get it right 90 out of 100 times then I wonder what the factory cams come out like. As far as picking a cam goes - decide what you want the engine to be like when it is done and how much money you want to spend. With a T5 you have more options. Putting a big cam into a relatively stock engine with the plan of hotting it up later will lead to dissapointment. Big cams need good heads, intake, exhaust and benefit from a chip. If you are not going to do the whole engine at once I would say go for the best bang for your buck now (DEV3?/Crow stage 2/Wade 1004-112), and then upgrade later if it ends up holding you back.
#17 | ||||
RIP...
I believe that is one of the contributing factors in what produces the great variances in performance between new vehicles. New car cams are ground by the very same grinders who make our performance cams. Only they need to made even faster with greater tolerances because of the amount being chruned out. Many people have increased performance by fitting a vernier gear to standard cams and clocking it up to spec. Rick.
#18 | |||
XB in parts...
#19 | ||
"THE" Workshop manager.
Guys...
All cams Dev2 thru to dev 5a are $490.00 All cams Dev6 thru T1 to T3 are $590 Springs to suit 3HL to 5a are $220 Springs to suit Dev 6 and all T's are $300 Some springs require special valve spring retainers, please ring for those prices....Dev 3hl to dev5a springs use Std retainers.
Jim Mock Motorsport AME Albury carshow Horsepower Hero 2005 AME Adelaide carshow Horsepower Hero 2005 AME Shepparton carshow Horsepower Hero 2005 AME Melbourne Highest horsepower 6 turbo 2005 AME Melbourne Highest horsepower N/A 6 2005 All Ford nationals DYO 10.5 and over champion 2005 |
#20 | ||
whats the price to get a dev3 cam fitted?? thanks
#21 | |||
XB in parts...
Turbo's ?
#22 | ||
is that 590 fitted, what else would i need to change if i went for a performance cam?
