Old 25-04-2005, 07:48 PM   #1
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Default Rwkw to Rwhp
Can any one help with this. How to take rwkw figures & turn than into rwhp figures?.
Thanks for your help.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 07:54 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
http://www.joshmadison.com/software/convert/
Download that mate..... its worth its weight in Gold....
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 25-04-2005, 07:55 PM   #3
Yaw
Ford Fanatic
Yaw's Avatar
Here is the equation
(Rwkw x Rim size)
_________________ = Rwhp
The number of spanners in a sidchrome
Set
Beats the hell outta me :
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 07:56 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
times it by 1.341022
13.21 @107.7mph
Old 25-04-2005, 08:01 PM   #5
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
try this site
http://www.sciencemadesimple.net/power.php
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 08:27 PM   #6
AUIII XR8 MAN
DJR TM#54
Thankyou svo347 & XRFPV8 both gave me the same figure.
Yaw how doe's your one work?
Old 25-04-2005, 09:25 PM   #7
rob_o
rob_o's Avatar
Yeah thats the one I always use.
rob_o is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 09:39 PM   #8
needfordspeed
I think it was a joke, that convert program is mint, I definetly recommend downloading it.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 09:44 PM   #9
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Here is the one i use :
http://www.onlineconversion.com/
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2005, 08:03 PM   #10
Schmaigz
HP to KW HPx0.746 = KW
KW to HP KW/0.746= HP
Schmaigz is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2005, 04:56 PM   #11
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
(Rwkw x Rim size)
Set
Did you get that Sidchrome Tool Set part from the 12th Man where he explains how to figure out the Duckworth-Lewis system?
Carless
Old 27-04-2005, 07:32 PM   #12
Yaw
Ford Fanatic
Yaw's Avatar
I was waiting for someone to recognise it.
Old 27-04-2005, 08:39 PM   #13
darkfang888
ED Fairmont 4.0L
kW x 1.341 = hp
hp / 1.341 - kW
PS: ft/lb x 1.341 = Nm
Nm / 1.341 = ft-lb
B'jabbers!
darkfang888 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 08:27 PM   #14
Steffo
LPG > You
Steffo's Avatar
I use the 1.34 conversion for all hp to kW things. Doesn't matter if its at the wheels or at the crank, its the same conversion.
For example, say, you've got a 200rwkW BA XR8. 200 x 1.34 = 268. That's 268rwhp.
For Nm to ftlbs, the conversion is 1.355. So, say you've got a 500Nm XR8, 500 divide 1.355 = 369. That's 369ftlbs.
Just to throw this oddity in, there's "ps", the measurement the Japs and French and not many others use. kW x 1.359 = ps. So, say this the famous Jap 206kW limit.. 206 x 1.359 = 279.954, which rounds up to 280. So, 206kW is 280ps.
ps and hp are very similar, hence why people often confuse the Jap 280ps limit to being 280hp, but it isn't. hp divide 1.014 = ps, so, 280ps divide 1.014 = 276.134... (rounds down to 276), so, 280ps is 276hp.
I still don't know how to convert the Japanese kg/m torque measurement into lb/ft or Nm, I've never really needed to use it.
Old 28-04-2005, 09:39 PM   #15
Pieoter
km/m x 9.8 = N/m
COLORADO RED FIESTA ZETEC
MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes.
ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001.
Pieoter is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2005, 10:01 AM   #16
AGRO
KB TECH SUPPORT
AGRO's Avatar
To roughly work this out fella's, I just add 33% of the total kW.
Jo Blow's car has 300Kw at the treads......300+100(33%)=400Hp.
Just divide the kW by 3, then add that figure to the kw.
Simple and quick!
Regards
AGRO.
AGRO is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2005, 11:19 AM   #17
Steffo
LPG > You
Steffo's Avatar
Its actually quicker to do 300kW x 1.34 = 402hp
