Old 31-01-2007, 07:50 PM   #1
ATSEIF DROF
Default Crazy Coolant!?!?!?!?!
Every now & then when I get home from a drive in my WQ Fiesta Zetec I can hear the coolant reservoir re-filling itself, kinda sounds like a bubbling noise. Is this a common trait? It doesnt happen all the time & the engine temp gauge is normal so its not overheating. Any thoughts?
ATSEIF DROF is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2007, 07:52 PM   #2
Teki04
Clio 182 CUP!
Teki04's Avatar
I used to have that same problem. I do believe it was from the coolant or something rather moving back from the water pump?
Had you been for a 'spirited' drive before hand? ;)
Steven
'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04)
Teki04 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2007, 08:06 PM   #3
ATSEIF DROF
Yeah that sounds about right, usually after a longish drive home from work in traffic. What did you do about it if anything?
Old 31-01-2007, 09:31 PM   #4
Danny
GT4.
Danny's Avatar
It's normal, and is the water pump releasing pressure back into the system which backs up into the overflow bottle. Get someone to rev the car while you watch it. It does the same thing ;)
Old 31-01-2007, 09:35 PM   #5
Teki04
Clio 182 CUP!
Teki04's Avatar
Bingo! Thanks Danny - knew it was something like that
This was why my Water Pump failed... causing the coolant to spill over my driveway :
Steven
Old 01-02-2007, 04:54 PM   #6
Danny
GT4.
Danny's Avatar
Ditto here. Mine went at a very young 6,000 kays...
Old 01-02-2007, 06:33 PM   #7
Teki04
Clio 182 CUP!
Teki04's Avatar
Mine was closer to 20,000kms...
Steven
Old 01-02-2007, 07:19 PM   #8
ATSEIF DROF
Fair enough. It would be under warrranty though yeah? A water pump should last 10 years really!
Old 01-02-2007, 08:47 PM   #9
Teki04
Clio 182 CUP!
Teki04's Avatar
Yep and yep...
Steven
