Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
Audi S3
Gday guys,
just have a small problem with the flash banners. they are constantly crashing all my browser windows... i use IE, and am in no position to change to an obviously superior browser like Firefox, but i have to make do with what i have. it says "Adobe Flash Reader 9.ocx" has encountered an error blah blah, something along that vein anyway and all my IE windows closed. i've currently disabled that plugin, but its a hassle, and want everything to work correctly... so does anybody have any ideas? cheers Henri
Is that version of flash player the latest?
I have the same problem. Was hoping that updating from IE6 to IE7 would help, but it didn't.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
#4 | ||||
Merry Xmas To All
I also have this problem. IE7 in use. It's not often, by usually at the most inconvenient time....
windsor user
im having the same issue using firefox i think....... thought it was just my pc, though it doesnt seem to do it on any other sites.....
Yep, got that version. I remember it updating too.
Beats me. I use IE7, IE6 and firefox with no problems
Now Prado Powered
No problemo here either.
Currently Fordless. But watch this space....... |
#12 | ||
There is a program called Spyware Blaster. In it you have the option to disable Flash in IE.
I just tried it then and the rest of the site still worked. Just a thought I had. |
#13 | |||
Former BTIKD
![]() Join Date: Mar 2005
#14 | ||
Hoon On The Rise
I have it too, big time....
it is a known issue with flash9b, and there are numerous threads on dobe support forums... They are working on the issue.... In the meantine here are two tips to help... Only have one or two windows open OR Disable the flash module in IE so it doesn't run the banners...... Cheers
![]() ![]() FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
#15 | |||
Audi S3
good (well not really) to see that i'm not alone. guess ill keep getting the updates as they come.
#16 | |||
I couldnt go without it lol |
#17 | ||
Forum Director
As mentioned, this is a very widespread issue, not just isolated to this forum.
Hopefully Adobe will pull a finger out and get to the bottom of it soonish. |
#18 | ||
Have these issues been more noticeable since Adobe took over Macromedia or were they common before that?
#19 | ||
Forum Director
Since version 9 fullstop.
It's been a dog since day one. |
#20 | ||
www.lukehimself.net
Hey mate I've had this problem too, and I have fixed it. From what I can remember you have to uninstall and reinstall, unfortunately flash doesn't remove all its files through their uninstall app, so you'll have to do it the long way.
First get the files msizap.exe from Microsoft and Uninstfl.exe from Adobe, I'm not sure where on the sites but search them and you should find. Reset your computer and make sure no flash stuff is running. Then when you have these files,: 1. run the uninstall command: %windir%\system32\msiexec.exe /X{BB65C393-C76E-4F06-9B0C-2124AA8AF97B** /qb- 2. run msizap: msizap.exe T {BB65C393-C76E-4F06-9B0C-2124AA8AF97B** 3. run uninstlfl.exe twice using the following switches: uninstfl.exe -q -u flash9.ocx uninstfl.exe -q flash9.ocx 4. If %windir%\system32\macromed\flash\flash.ocx still exist, delete it manually Should work, then install the latest version. You should be able to find this fix on sites but its a bit hard to find. Here's probably a better one from another site 1. Use the uninstaller at Adobe's Web site following the instructions given here: http://www.adobe.com/cfusion/knowled...fm?id=tn_14157 2. Empty temporary files and internet cache and restart. 3. Download the latest FlashPlayer version 9 from Adobe's web site here: http://www.adobe.com/shockwave/downl...on=ShockwaveFl ash At this point check and be sure that you have a file named "Flash.ocx" in both your Windows\ServicePackFiles\i386 and Windows\System32\Macromed\Flash folders, as well as the "Flash9.ocx" in the Windows\System32\Macromed\Flash folder. If you do, you have a good install. 4. Download Flash8.ocx from www.rrdownloads.net/Flash.zip (I suppose that file is buried somewhere on Adobe, but I couldn't find it; nonetheless, this link is a safe one) 5. Unzip the active x file into your Windows\System32\Macromed\Flash folder 6. In the same Windows folder, rename "Flash9.ocx" to Flash-9.ocx (or anything else) 7. Then rename the Flash8.ocx (from the downloaded zip file) to Flash9.ocx Restart et voila ... no more crash errors. Caution: This fix has worked for me on a WinXP Pro and WinXP Home O/S, running IE6. I cannot vouch for any others. I hope it works for you! Good luck. It really annoyed the hell out of me. (And print out the instructions, makes it a lot easier ![]() |
#21 | ||
LPG Forum Moderator
delete flash 7 or 9 from your program files and leave only flash 5 it worked for me.
#22 | ||
XR5T - Sea Grey.
Same issues as everyone else (IE7 Vista). I tend to open new tabs from the main page of all the sub forums I want to visit and this is when dramas occur. You can ride your luck a bit though, sometimes it wont crash for a while, other times its the moment you open a 2nd window.
#23 | |||
Cuban... nothing like it
Strange
Just loaded Vista and several browsers and have not had a problem, no help to you but I am happy.
