Over Thinker
extra advice or a second opinion offered (only owned one myself )
Have to pm me for more detailed info or find me in the telstar post dont come here too often 1200,1300, 1500-1600 GT- If someone is stuck I can do a walk through on some procedures posts to be added later some specs firing order 1243 plug gap 25 thou points 14-16 thou timing 1200-1500 6 deg btdc timing 1600 GT 10 deg btc email alternator 35 amp C40 generator 240 watt/22amp
My car goes Brumm Brumm |
Heavy right foot
what advise were you wanting exactly?
Over Thinker
you already know heaps - thats good
www.cortina-mk1.com people can ask you as well giving advice only given a registered owners manual 1964 model thats an intresting read (not for sale )
Heavy right foot
oh i see your..offereing advise
![]() a bti confusing the thread title ![]() |
Over Thinker
torque specs in ft lbs
1200 -1500 GT head bolts 70 main bearings 60 big end bearings 25 flywheel 50 rocker shaft supports 20 mark 11 series 67 type motor same as above if not listed below big end bearings 30 crank pully 28 camshaft sprocket 15 manifold securing 18 MK 11 68 type motor same as above 1300-1500 rpms 600 +-20 1500GT rpms 700 +-20 oil pressure 40 psi hot sump capacity MK 1 1200-1500 GT 6 3/4 pints with filter 67 type models MK 11 1300 5 1/2 pints " MK 11 1500-1500GT 7 pints " MK 11 1600-1600GT 7 pints " 68 type models MK 11 1300 6 1/2 pints " MK 11 1600-1600 GT 7 1/4 pints "
norris
ok then know all....
1500 pre x flow wont start 1 removed rocket cover located #1 piston exhaust valve stiil down piston on way up exhaust / inlet still closed. mark on harmonic balancer meets the lower mark on timing cover .rotor button on #1 piston points open points gap set @ 0.40mm which =0.015 good so far , understand what ive done . 2 wind motor over wont start new fuel,filter,points,rotor button,and distributor cap all electrical connections look clean motor hasnt been started in a while now go and rack your brain for the solution for me. thanks norris |
Over Thinker
the number one piston should be at its full upper travel and both valves closed signifing top of compression and at TDC when the spark is delivered
use the finger method to varify this fact about the top of compression with the ign on ...see if the points break at the right time when you have number one at TDC .... re- set timing to suit recheck rotor position firing order of the leads on the cap and plugs you might have the engine on number 4 cylinder right up as you said the points are open and valves of number one has one open one closed next problem you may have is the harmonic balencer has slipped on the rubber inset putting the timing mark out try that
My car goes Brumm Brumm Last edited by dirty hands; 23-01-2007 at 04:42 PM. |
norris
well done lad , the thing is that ive done all of what you said, and ive spoken 2 a mechanic he said that the timing is out 180 deg so the easiest way out is reset the spark plug leads to 4 as 1 and start the firing order that way i dont like it but if it works then y not.
i'll give you credit for problem solveing regards norris |
Over Thinker
put the number one cylinder back up as in the previous post
take out the distrbutor and rotate the rotor of the dissy 180 degress till it faces to the num one cyl on the dissy cap and lead the timing pully should be right
norris
well hows dat still didnt fire removed dizzy rotate 180 made sure thats it on #1 bought another coil it might be a intermitting fault in the electrics if it dosent start soon i'll put both barrels to the radiator and shoot the f....er dead.. nah only jokin
Over Thinker
HAS some one been playing with the engine ? was it running at all before
the engine has a timing chain if it was replaced it may not be fitted correctly if the compression is good /not a problem are you getting fuel delivery to the chambers set the dissy and rotor up so it sits just before it reaches the number one terminal of the dissy while the piston is at TDC at that point the spark fires right at the pick up contact on the num 1 dissy pick up - lead and plug and not after it has pased if it starts advance the dissy timing to 6 degrees
#12 | ||
norris
motor was runnig prior to me removing,fuel pump and carby as there was corrosion in the bowl [water] carby needed [air blow out],replaced pump [electric],then motor started, then exhaust manifold started to glow cherry red, timing is /was out ive taked all day to sort it out now it runs ok mixture needs to be set so now it runs.
thanks for your help norris |
Over Thinker
good news watch out adelaide
you may already know this .so I put it in for others carby set hot set idle at 500 rpm screw in mixture screw clockwise till engine slows and falters then screw mixture screw anti clock wise again till the engine runs smooth re adjust idle stop screw and may need a twig of the mixture screw to balance engine idle mixture screw clockwise lean / anti clock wise rich . different float level heights for the differnt carbies have to know which one you have solex pse type/ zenith vn type /ford manual choke /ford automatic type a webber dual barrel type .
#14 | ||
norris
zenith vn type
#15 | ||
Over Thinker
zenith vn type thats an intresting carby
I have 3 1/2 pages on that one (carby set up as above for the zenith vn type) float is marked top to face up you can adjust the fuel pump stroke lenght should have two lugs on a thread with a spring (accelerator lever to carby top cover ) the long leg for short stroke ....... short leg for longstroke of the carby fuel pump
#16 | ||
norris
yep
that would be rite if i had that type of fuel pump mine is electric 5 to 8 kpa which should be 2 imperial gallons @2000 rpm, i think the pressure feed is 1 to 2 lbs/per sq inch |
#17 | ||
Over Thinker
yes thats a good flow rate
#18 | ||
norris
well dirty hands Thanks for your time and help
