Old 17-12-2006, 05:00 PM   #1
reded
ThUmPeR
reded's Avatar
Default Amp wiring question...?
i know that your not ment to run the power cable and the RCA cables on the same side of the car...
but wat if the RCA leads are from a different amp?
is it ok to do that or not?
just asking because im about to start the wiring part of my custom boot..
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
2.5" exuast, Pacemaker extractors
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
clear indicators all round
Full EL Ghia interior
reded is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 05:29 PM   #2
El_Poochino
It's best to keep all your RCA leads seprate from all your power leads. Current can cause interferance.
El_Poochino is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 05:56 PM   #3
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
keep em away.... far away. i thought it may be ok to cross them at right angles (eg +) but even that is no good.
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 06:33 PM   #4
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
thats why the rca and power is on different sides of the amp
i worked it out the hard way, has to go on the other side and im running 2 amps witth 1200rms
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 07:49 PM   #5
!Gn|T|0n
!Gn|T|0n's Avatar
Yes you should keep them separated. Even if the signal and power cables are for different amps, you've still got the situation where surges of current drawn down the power line will electro magnetically induce signal distortion on the RCA lines. CaRtZ
is correct by saying that induction is most efficiently coupled through parallel conductors, but running perpendicularly crossing cables through a car is impractical.
Still saluting the Ford flag.
!Gn|T|0n is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 10:46 PM   #6
Kyle.L
So basicly, you have to keep all rca's down one side (left in your case would be best) and all power down the right (closer to battery). Regardless of which go to what amp. Also run speaker cables down with the rcas.
Kyle.L is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2006, 08:20 PM   #7
reded
ThUmPeR
reded's Avatar
ok thanks heaps for the help guys.
hope my RCA leads are long enough to reach into the side of the boot..
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 18-12-2006, 08:41 PM   #8
tabletennisman
tabletennisman's Avatar
cheers troy
My 5m RCA cable JUST reaches. The amp is located on the right side of the boot, and the rca runs along the left side of the car.
tabletennisman is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2006, 08:58 PM   #9
reded
ThUmPeR
reded's Avatar
ah ok they need to reach nearly the lail lights on mine:( i might be able to get the amp a lil bit closer hopefuly.
can i connect 2 sets od RCA lead together or will it not work?
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 18-12-2006, 09:00 PM   #10
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
my 5m rca reach with about 20cm to spare. cant wait to c this setup troy.
EF Wagon Project:
Old 18-12-2006, 09:01 PM   #11
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
i think jaycar in high st has 7m.
EF Wagon Project:
Old 18-12-2006, 09:18 PM   #12
reded
ThUmPeR
reded's Avatar
ah well all i can do is see if they reach and if they dont i will go to jaycar, thanks pat.
yeah im gonna post thread til its done bit more suspense and not been a thread whore :P
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 18-12-2006, 09:53 PM   #13
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
lol u should start a build thread in the workshop section...
EF Wagon Project:
Old 18-12-2006, 11:18 PM   #14
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
oh lucky i read this thread. i had no idea about running the power and rca's seperately. i will be taking this into account now that i know. thanks aswell
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread
2008 FG XR8 SEDAN 300RWKW N/A
2008 FG XR6 TURBO-UTE>>> SOLD
2002 AU3 XLS UTE>>>SOLD
Sick EB is offline   Reply With Quote Multi-Quote with this Post
