Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 08-12-2006, 07:37 AM   #1
MoreHPformyXR6
MoreHPformyXR6's Avatar
Default Thermostat BA I6 NA
Originally Posted by 05MkIIFutura
Mine never moves from about 1/3 (just a tad less than half between 1/4 and 1/2)
Only time it jumps up is towing up Clyde or Brown mountain, but even then it is only slightly more than half way between 1/4 and a 1/2
Given this, is there any benefit for me (highway and easy city driving only) to run the engine cooler (say at 1/4)??
Originally Posted by Falcon73
Got the figures
160 f = 71.111 celcius
170 f = 76.666
180 f = 82.222
190 f = 87.777
200 f = 93.3
So to clarify if I put a 160 rated thermostat in a ba xt that has exhaust air intake as the only mods no flash tunes or edits will this cause problems with the car staying in warm up mode and using more fuel etc.
Hi Chris
I was hopeing you may be able to answer the above questions.
Scott
FGX XR6 Lightning Strike Sedan
BA XR6 Mk II Shockwave Sedan - Now Sold - gone but not forgotten
mods: 20% under drive, Pacemaker Comps 4495' (ceramic coated) , 3' Metal Cat, XR6T exhaust - twin 3' tips, F6 CAI, K&N panel filter, PWR trans cooler, customed tuned by Heinrich Performance Tuning HPT 183.7rwkw.
Originally Posted by ATMO SIX
You have become the new SLOANY mate, no real quality to your current post(s).
MoreHPformyXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2006, 09:15 AM   #2
Bluepower
KenneBell Australia
Bluepower's Avatar
Installing a different mode thermostat will require different fan settings. I would only do it with a tune.
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2006, 09:24 AM   #3
MoreHPformyXR6
Thanks for that Chris :eclipsee_
Old 08-12-2006, 09:35 AM   #4
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
Not necessarily. As long as the thermostat opens once the engine is hot enough that ecu is no longer in warm up cycle, there is no issues...
Fans still kcik in when hot enough...
When it opens before ecu has come off warm up you need to play with the tune....
Tested all this on my BA and have no issues...
When using the edit, cooler detonation should allow more timing... Careful with heat ranges on the 6's but, too cold will cause adverse wear on cylinders and valves.....
Stomp 'n' Steer
FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com
Bluehoon is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 12:58 AM   #5
Ruger
Bseries Moderator
Ruger's Avatar
i found with mine since the tune hasnt been altered for it temp will just rise slowly to just under half (a little lower than stock) if the point where the thermos come in was altered it would keep it a little more stable. mine seems to wander a little.
fans will kick in when hot enough yer im not sure if the t is any different but with the na high level on the thermos doesnt come in till half way and temp will just creep up slowly defeating the point of the thermostat. with the thermostat fitted and a tune that doesnt suit im really relying on the weather on a cold cold cold night it will sit at the 1/3rd point but in warmth or traffic itll just creep up and the thermos stay on low till it gets to half.
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2006, 09:25 AM   #6
Bluepower
KenneBell Australia
Bluepower's Avatar
Ben, did you log your BA?
Old 11-12-2006, 09:32 AM   #7
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
yes. used the logger from sct...
Stomp 'n' Steer
Old 11-12-2006, 11:05 AM   #8
Bluepower
KenneBell Australia
Bluepower's Avatar
how did your act temp trace look like with stock fan settings. Also, bear in mind we use a 160f stat.
Chris
Old 11-12-2006, 10:20 PM   #9
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
Chris
I am using BPT one - opens at 82 Dg, Clecius. Not sure by what you are referring to mate.
Stomp 'n' Steer
