Old 14-11-2006, 10:29 PM   #1
XEESP_351
Default 220 broken valve spring
hey boys sounds like every1's 220 eating poo at moment :
Mine started running rough on sunday..I carried out the normal tests and came to the conclusion it was a mechanical failure..I pulled the rocker cover off the left bank tonite and found i have a broken or weak valve spring on no 8 exhaust valve..Obviously this is a common fault
Im planning on just replcaing that one by having air injected through spark plug hole to keep valve up and removing and replacing with valve spring tool..
My questions are wot is the availabilty on these do most dealers stock them? Are they off a diferent strength to standard?
And i found mine has Yellaterra rockers are these factory?
cheers
XEESP_351 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 11:41 PM   #2
Baboon_AU
Baboon_AU's Avatar
yella terra rockers are not not standard.
you can purchase the spark plug air fitting from coventry's and you could also get the above head spring compresser from coventry's/repco.. its pretty easy to do mate. u dont have a problem. just dont drop the collets when u take them off
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 12:31 AM   #3
xr8ute
Back on the road
xr8ute's Avatar
YT rockers are standard on the 220kw XR8 engines.
The spark plug fitting will be less than $10, and the "on head" valve spring compressor about $30...its pretty easy to change using this method.
I would question the value of only changing a single spring though..?
How did you come to the conclusion the spring on #8 exh is "broken or weak"..?
Old 15-11-2006, 01:58 AM   #4
fordAU
Not good Mr T, sounds like a few 220's are falling over atm, drive one myself so fingers crossed.
As XR8Ute has pointed out YT's are factory standard on these ones.
fordAU is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 09:16 PM   #5
XEESP_351
i did a compression test and found no compresion then every now and then would get a little..Took off rocker cover and removed cyl no . 8 rockers and was able to push exhaust valve down with my fingers
Im only replacing one as am unsure of which way i want to go i might hottie the motor up at a later stage as i am looking into buying a new project at the moment....Am waiting on the new spring genuine from ford at the moment (ordered today) 20 bucks, ex east
Old 15-11-2006, 09:23 PM   #6
XEESP_351
mine has over 120k on it and manual so if they are a problem and only 1 gone so far (well as far as i no) will see how things go sometimes u can get weak ones in batches. I bought second hand with 114k on it
Old 15-11-2006, 09:33 PM   #7
Baboon_AU
Baboon_AU's Avatar
sorry,. i didn't realise 220's came with YT rockers
Old 15-11-2006, 09:37 PM   #8
RG
Back to Le Frenchy
RG's Avatar
Hope it all goes well, you got lucky. What is it with no. 8 cyl lately?
Old 15-11-2006, 11:27 PM   #9
fordAU
Good luck with it, hope you are back on the road soon.
Something about these 220's especially manuals that us owners probably agree on, they are like a cranky child, moody with bad manners but utterly loveable.
Now I feel like heading out to the garage and giving mine a hug :
Old 16-11-2006, 08:28 AM   #10
james22
With da Warlords
james22's Avatar
Now ain't that the truth lol, I wish I could give mine a hug :nutsycuck
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 22-11-2006, 12:23 AM   #11
XEESP_351
Just like to note that shes all fixed and purring like a kitten again.
Quite an easy job in the end for such an integral part of the motor.
Old 22-11-2006, 07:54 PM   #12
Baboon_AU
Baboon_AU's Avatar
did u fix it using the spark plug adaption and over head valve compresser?
Old 22-11-2006, 10:30 PM   #13
XEESP_351
yes it only too around 2 hours total from start to finish (driving in driving out) thats including working in the dark and being distracted by the missus..My sheds not very well light.
Old 23-11-2006, 07:36 PM   #14
Baboon_AU
Baboon_AU's Avatar
good for you mate. well done
