Old 08-10-2006, 05:35 PM   #1
XR8-260
Default G-tech
hi, i was thinking of buying a g-tech device of ebay. Does anyone know how accurate it is? i.e. has anyone compared their gtech 1/4miles to their drag strip (caulder park etc.) 1/4 miles?
cheers
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 03:55 PM   #2
superpursuit83
KITTY Crew Member
superpursuit83's Avatar
Hi mate, I have a Beltronics meter and is within .2 of a second when set up roughly. They are pretty accurate when set up properly with weight angle of car, aerodynamic efficiency etc.
Maybe Jamie with the TE50 will chime in here, he has used mine more than me
FOR SALE
BAII Super Pursuit 0083
Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block
Awesome exhaust by THE EXHAUST CENTRE MIDLAND
Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments
Now with full DOT approval and Permitted for road use
superpursuit83 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 03:56 PM   #3
superpursuit83
KITTY Crew Member
Hey Just noticed your in Perth, if Jamie has done with it I will let you trial mine if ya like
FOR SALE
Old 09-10-2006, 05:50 PM   #4
XR8-260
Hi mate,
I think you've answered my question and i should be getting one off ebay when i have enough money :. Thanks for the offer but i wouldn't want to trouble you.
Old 10-10-2006, 07:30 AM   #5
ThoR_
Holdens Fall Apart!
ThoR_'s Avatar
i have been told there very un accurate by alot of people? but then guys say there good so :S
AU2 XR8, Venom Red, 200kw, K&N Panel Filter, 2.5" Lukey Exhaust
ThoR_ is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 10:13 AM   #6
superpursuit83
KITTY Crew Member
They are not too bad if you set them up correctly, but they are fairly consistent which is enough to get an indication whats going on.
FOR SALE
Old 10-10-2006, 10:36 AM   #7
SunDrifter
To shreads you say?!
SunDrifter's Avatar
I have one. I can't really comment on its accuracy, because i don't really have access to anything more accurate. But once setup properly, i'll agree that they are at least consistant. At least good enough for before/after runs when modding/tuning.
BAII XR6 Ute (manual) Winter white.
Originally Posted by VYBerlinaV8 (LS1.com.au)
I've owned Holdens and Daewoos, and had plenty of problems with Holdens and none with Daewoos. Of course, the Holden is the more desirable car to own and drive, but based on my experience it is not the higher quality of the two.
Originally Posted by SlickHolden
Weight means nothing to a cars handling...
SunDrifter is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 08:39 PM   #8
joshf2
striped
joshf2's Avatar
the main problem is that you have to use it on a flat stretch of road.
inclines seem to wreck havoc with the accelerometer
joshf2 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 08:45 PM   #9
ssb2005
Scrubber Racing Team
ssb2005's Avatar
a gtech/ vbox etc wime will always be up to .4 different to a drag strip timer cos of the way they work. they are consistent when compared to other g-techs tho
www.cardomain.com/id/ssb2005
2001 TM Racing 250 2T enduro.
1992 Falcon S XR-6 161+Kw's zorst, chip, tickford engine and ecu
1984 AB GSR Cordia tidy up time. DASH is here!! future track weapon
1973 Yamaha RD 250 project cafe racer
ssb2005 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2006, 04:45 PM   #10
XR8-260
Lucky I know the perfect flat stretch on the freeway (between ocean reef and the hodges exits) :
How accurate is the car's odometer? I often reset the trip meter to zero, floor it and then stop when i reach 400m. I have been reaching speeds of 155kph - but then again i hear the speedometer isn't 100% accurate.
Old 13-10-2006, 07:10 PM   #11
ssb2005
ssb2005's Avatar
its about 5-7% our if your unlucky
