03-10-2006, 11:45 AM | #1 | ||
With da Warlords
Its like a jigsaw puzzle, fill in the blanks.
Serously though, if anyone knows a number chuck it in. Hopefully all the specs will shine through. Thanks Bore = 101.6mm Stroke = 76.2mm Rod Length = 6inches??? INTAKE Valve Diameter = No of Valves = 2valves per port??? Port Diameter = EXHAUST Valve Diameter = MANIFOLD SPECS Runner Diameter = Runner Length = CAM SPECS INTAKE Centreline, ATDC = Duration @ .050 = Max Lobe Lift = Rocker Arm Ratio = CAM SPECS EXHAUST Centreline, ATDC = Duration @ .050 = Max Lobe Lift = Rocker Arm Ratio = Advance / Retard =
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
03-10-2006, 11:45 AM | #2 | ||
With da Warlords
for a 220kw engine.
03-10-2006, 12:20 PM | #3 | ||
fuel injected or carby
03-10-2006, 12:32 PM | #4 | ||
With da Warlords
fuel injected, series III xr8 2001'
03-10-2006, 10:56 PM | #5 | |||
AU DIE HARD
http://www.fordforums.com.au/photos/...cat=961&page=1
have a read through this lot you should find most of the info you need .. I gave up after page 3 : only head specs & cam are a bit differant on the 220.. enjoy ..Cheers ..Whoosha
04-10-2006, 10:43 AM | #6 | |||
With da Warlords
04-10-2006, 10:27 PM | #7 | ||
XD197
didnt work for me either, i can tell you for sure that a 302 pushrod windsor only has two valves per cylinder, one inlet, one exhaust. the bottom end is the same from eb to au except for 250 kw. some of the 220s got alloy heads and some didnt i think. apparently the alloys arent all that flash from the fact they all got phased out quick and they went back to cast iron, saying that i would rather have an alloy headed 220 than a cast iron 175 haha . beggers cant b chosers :monkes:
