Old 09-09-2007, 08:41 PM   #1
melbzetec
Old enough to know better
melbzetec's Avatar
Default Bosch Aerotwins
Also did this cheap upgrade over the weekend. This is very popular mod in the UK
Bosch Aerotwin wipers now available at Supercheap. About $43.00 for the pair. Replaces the entire wiper arm (which were also Bosch as OEM). Looks much simpler and cleaner, runs more quietly, and seems to fit firmer against the windscreen
Old 09-09-2007, 09:04 PM   #2
photn
AFF Post NAZI
photn's Avatar
product code. that was on my mod list.
can you also give me the place and price for the covered rear wiper steve?
Old 09-09-2007, 09:13 PM   #3
melbzetec
melbzetec's Avatar
I got the covered rear wiper from..........
.......good old www.european-parts.net.
I'm not sure of the code for the Bosch Aerotwins, but you need the 22" and the 19"...and they mention Focus on the back of the pack!!!
Old 09-09-2007, 09:15 PM   #4
FOCUSonTHIS
FOCUSonTHIS's Avatar
What a gun Steve.....I need new wipers
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 09-09-2007, 10:37 PM   #5
BlackLS
They are so much better than the regular type. I'm glad the LS has this stock.
Old 10-09-2007, 01:10 AM   #6
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
Thats a nice looking wiper
goto a Peugot shop and get a 206 rear wiper arm, looks a lot cleaner then the focus one and fits right on
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 05:08 PM   #7
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
My wipers are rubbish. i'll look into these.
i've heard of guys using mazda 3 rear wipers. i like the look of those.
...my sister owns a mazda 3, hmm...
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2007, 11:09 AM   #8
More revs
Anyone know if they will fit on the LS??
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2007, 11:15 AM   #9
melbzetec
melbzetec's Avatar
I think they are standard on the LS
Old 12-09-2007, 12:06 PM   #10
More revs
They look similar but I couldnt remove them from the packaging without purchasing them. I'm not sure if they will fit. The packaging specified LR Focus....
The passenger side on my LS needs replacing so if they fit AND are cheaper than Ford I'll get a set.
Old 12-09-2007, 12:50 PM   #11
BlackLS
Can you just replace the rubber blade inside the aerotwin?
Old 12-09-2007, 02:17 PM   #12
photn
AFF Post NAZI
photn's Avatar
nah you cant. they are normally fussed in together. and you have to replace the whole arm.
Old 13-09-2007, 10:16 AM   #13
whippet_zetec
Supes
whippet_zetec's Avatar
that sucks! and can get exy if you use your wipers alot.
Yes I DO drive a Toyota
whippet_zetec is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 12:21 PM   #14
20focus05
I wanna XR5
20focus05's Avatar
For the LS I got a quote for wiper blades for around $25 a pair. On the LS the blades are removable by lifting the arm and rotating the blade upside down and they slide out.
With a bit of care the rubbers are removable, carefully remove one of the plastic covers at one end, A small flat blade screwdriver down the rubber slot and push on the tab holding the end cap on. At one end the rubber is held in place by a tab squashing on the rubber. now different coloured rubbers can be put in.
Bit of useless info for you
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 05:04 PM   #15
FOCUSonTHIS
OK just for you
Driver: BBA550
Passenger: BBA475
Also paid $46 for the pair on special at super cheap
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 17-09-2007, 07:12 PM   #16
FOCUSonTHIS
Just done the mod today and it wipes so much smoother across the screen. Just need it to rain(which is most likely tomorrow) for the real test.
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 17-09-2007, 08:42 PM   #17
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
have they got them for Cougars?
Old 18-09-2007, 12:03 PM   #18
FOCUSonTHIS
Measure the size of your wipers blades and get the same size if they have them in the Aerotwins
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 18-09-2007, 08:31 PM   #19
More revs
No these dont fit on the LS Focus.....
Old 18-09-2007, 08:48 PM   #20
photn
AFF Post NAZI
photn's Avatar
cause they come standard on them.
Old 19-09-2007, 09:36 AM   #21
More revs
Ok.. The Ford version is different slightly. The wiper element can not be removed, I've tried and so has a Ford service dept. Sure you can butcher it out but the replacement wont go in easy and the result is a shuddering sweep.
The aftermarket Aerotwin comes apart eaily so the blades can be replaced as needed. So I would like to put these on rather than the genuines.
I told you I was cheap...
Old 19-09-2007, 09:45 AM   #22
BlackLS
yum
Cheapness FTW!
2005 LS Focus LX
250,000kms.
Old 19-09-2007, 05:00 PM   #23
FOCUSonTHIS
Well it finally rained today! I have to say that this blades are the best so far! No noise, smooth and shudder free! I am a happy camper!
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 20-09-2007, 07:11 AM   #24
More revs
And that grawwww grawwwww noise your heard earlier was me..... lol
