Old 13-09-2006, 08:46 PM   #1
Mikey B
Frozen White Focus RS
Mikey B's Avatar
Angry ST170 Cat Heatshield Rattle
Hi All,
Wonder if anyone can advise?
I had the ST in at a Ford Dealer here in Bris to take a look at the CAT underbody heatshield as it was rattling and V. annoying.
I was under the impression that as this is a common issue on the ST's (prone to fatigue and splitting at the mounting locations), this work would be covered under warranty?
However i picked up the car tonight and got charged over $100 for 'tightening' 2 bolts! What makes it worse is that the problem is still there and they've clearly done sweet FA.
I asked why they charged me, only to be told we can't claim tightening bolts under warranty! I said to them '2 things':
1. If it was a simple tighten job, then I would have done that myself.
2. What IF my engine spat a piston thru' the block as a result of a con-rod bolt working it's way loose. Would this be claimed under warranty even tho' the route cause was a loose bolt? They said "of course this would be covered".
The car is going back AGAIN on friday now for them to have 'another look'.
Any advise on what I can do to get my $100 back and get this fixed under warranty as it does require a new sheild???
Cheers,
Mike
Mikey B is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2006, 10:00 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
My suggestion?
1. Write to the Dealer Principal, in a calm, rational manner (not "your service department is manned by morons, a pack of monkey's could do a better job etc etc") setting out your issues (a. Warranty, b. $100 for tightening two bolts). Ask him to ring you, or request a time to see him.
If that fails
2. Write to the Ford Customer Service Division.
If that fails
3. Write to Tom Gorman. Ask him to reply personally and not get some flunky to write a lame response
If that fails
4. Draw up an ad that says "XYZ Ford charged me $100 simply to tighten two bolts. I will never take another car there..ever". Send the ad to the dealer and tell him you'll be running it the local paper unless he can address your issues.
If that fails
5. Run the ad
Old 13-09-2006, 10:43 PM   #3
Blue_ST170
Blue_ST170's Avatar
i agree with melb about geting the money back but on the cat side of things my cat both came loose and cracked. You have to be carful cause they tried to fix mine and pushed it too far up, breaking the co2 sensors off. It a really bad design as the sensors r about a mm from the heatshield. I ended up having to pay $400 for new sensors cause i needed the car to run then it happened again and after a hue fight they fixed it for free.
In the end i had to get a new cat, which i bought from hitech for a few hundred instead of ford who wanted about 5 grand cause its a special one for the st170 they order from england. The hi tech one got me some power anyway.....
Also I only found out the problem caue i took it to another mechanic. Ford r ******* idiots and dont know a thing....
03' Imperial Blue Focus ST170
Bluefin Level 2 tune, Custom extractors, Hi-flow cat,
K&N panel filter, EBC Turbo rotors with Greenstuff pads.
Saving for: cat-back exhaust
Blue_ST170 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2006, 10:47 PM   #4
b2tf
not here much anymore
b2tf's Avatar
Im amazed you even payed it in the first place. If i was presented with a bill like that for such an absurd job, I would flat out refuse to pay it.
2024 F150 XLT
Old 14-09-2006, 01:14 PM   #5
n1kol1s
n1kol1s's Avatar
Ratling and loose bolts are very common in a new car . i agree with melbzetec and you sould call consumer affairs and even ford customer service aswell. i heard that some censors and plastic clips on the focus genarly are very easy to break . The dealer sould take the responsibility and replace them without charge....
I put myself the hella eurostyle tailights and when i took it to the dealer to adjust the a noise comming from the boot they wanted to charge me 45 bucks for the job sayng the noise was comming from unpropper way the light were fitted. I just laughted and i told them that i fitted the lights myself and they had nothing to do with the boot .I went inside and i talked to the manager and i didint pay the $45.
n1kol1s is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 12:01 AM   #6
Blue_ST170
Blue_ST170's Avatar
lol well dont ******* start me on the plastic clips ford uses for everything...turns out even the gearbox in the st170 is held in with plastic clips....
they snapped and the gears started moving around till i got stuck in second cause the whole box had fallen sideways.....anyway they towed it for free the said its all under warranty but when i went to pick it up they trird to charge me for the towing and fixing it......had to fight for an hour with the manager but didnt end up paying....
n1kol1s can u send me some pics of ur car...and also where abouts u live??
Old 15-09-2006, 09:14 AM   #7
n1kol1s
n1kol1s's Avatar
I live in melbourne m8..
http://wrl.homelinux.com/index.php?o...mid=26&catid=8
Old 16-09-2006, 12:54 AM   #8
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
Had the same problem with mine, they screwed me over and tried to charge for fixing a couple of bolts as well.
Wasn't even the problem, check the actual mounts for the exhaust, more then likely one of them has broken and causing the rattling.
Thats what happened with mine, ended up paying $90 to a local mechanic who i trust to fix it rather then going back to ford with their useless inept service
Chris
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 08:20 AM   #9
Mikey B
Mikey B's Avatar
Many thanx for the replies. I'm in the process of sorting the refund out with the service manager at the dealer.
Chris (Adelaide) - Thanks for the feedback, i'll take a look at the mounts.
I need to get this tizz fixed as it's turning heads where ever I drive and waking the neighbours!
Cheers,
Mike
