Old 21-08-2006, 08:58 PM   #1
Peej
Default Sub and Amp
Hey all,
just wonderin what everyones thoughts are on running a sub and amp of the stock head unit. Anyone heard of any problems?
Peej is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 09:11 PM   #2
robbo_23
robbo_23's Avatar
Depends if the stock head units have RCA out, which i serously doubt
robbo_23 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 09:18 PM   #3
MISTA FIESTA
Da Shifty One
MISTA FIESTA's Avatar
Im currently running all pioneer gear = 2 amps 2 subs, 6inch front 6x9s in rear all from the stock HU. Only problem is you will lose the fade function. which hasnt really bothered me. There are no RCA Outs too.
2013 Ford Fiesta ST - Frozen White - AU 0072/XXXX
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade -
MISTA FIESTA is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 09:19 PM   #4
photn
AFF Post NAZI
photn's Avatar
ive got one off my stock unit, you can get a line converter and hook it to your stock speaker cables and it will convert it to RCA output. it sounds awesum and goes HARD. you will find that many ppl have, and different ppl will tell you to buy different subs and amps. i just bought a clarion cost me 90 and a scnider 2 channel amp which cost me 180. installation (carton of crownies = 50) and wiring KIT 35. simple really, the hardest part u may have is iff you have to take the head unit FACIA off, thats a *****.
Old 22-08-2006, 07:01 AM   #5
Scareybear
GRRRR.....
Scareybear's Avatar
I've done the same as Photn, used a line level converter, works pretty good while still leaving the stock headunit, as Mista Fiesta said you lose the fader, but if you used 2 line level converters, running off thr fronts and rears you could avoid this, all depends on if you're going to add more than just a sub...
Now - 2007Renault Megane sedan, Steel Gray, 19" Koya Ambush with 235/35R19 Yokohama ADVAN V103, Eibach Pro-Kit.
Gone but not forgotton - Diamond White 2004 LX Fiesta
If you sneeze with your eyes open, do your eyes pop out??
Old 22-08-2006, 06:43 PM   #6
Swaytan
Swaytan
Swaytan's Avatar
I've got the stock H/U, sounds fine dude. Though an aftermarket H/U will increase the clarity heaps.
Swaytan is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 11:49 PM   #7
Pieoter
Line converters will be your best bet, but your still gonna have the disadvantage of double amping the signal
COLORADO RED FIESTA ZETEC
MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes.
ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001.
Pieoter is offline   Reply With Quote Multi-Quote with this Post
