Adapt or perish...
It doesn't really concern me much, but I'd thought I'd post this up to see if anyone else has this problem.
I get a coolant leak from the hose that travels above the radiator/thermo fans (where I've circled in this pic taken from AUFalcon.com) ![]() Now, the reason I'm not worried about it is that the temp stays in the normal range for the ute (between N and O), but it leaks from out under it and cakes onto the engine. Should I be worried about it? I've had the hose replaced and it hasn't fixed it.
Carless
PM me if you want
I would not worry too much, but a leak can only get bigger and worse over time as a general rule, and then it will let you down in the middle of no where, when you can least avoid it to happen.
New thermostat housing cover is cheap, think about changing it ![]()
#3 | |||
Adapt or perish...
I'm still learning the ins and outs of the engine...
Carless
Formally Kia Chaser
Yeah, and from memory, I think you can get fully chromed ones from ebay... a new hose and hose clamp might be a better alternative first (if it leaks from the hose that is...).... good luck...
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#5 | |||
Adapt or perish...
Carless
![]() Join Date: Jan 2005
Are you sure it's leaking from that hose? Mine was leaking from the thermostat housing itself (lost about 500ml of water in a month). Nothing too bad, but I hate the smell of cooking coolant, and it stains everything it touches.
#7 | |||
Adapt or perish...
I lifted the bonnet yesterday to do some adjusting with gas mixtures and can see caked on coolant. I'll get a pic tonight and post it up tomorrow.
Carless
Replace the hose as well. Over time the hose goes hard and resists clamping pressure to seal. Do this and use utilux type clamp and clean spiggot and smear lightly with grease and it will be fine.
they call me Tibbo
it looks that car is still using the gay Ford squeeze band clamp... Pi$$ that off Kenny and use a std hose clamp if you haven't already
#10 | ||||||
Adapt or perish...
Before I post this pic of MY engine bay, the one I posted earlier was of someone else's car that I got off AUFalcon.com to show where I was talking about.
This is the leak in question... ![]() Sorry for quality of pic. See just under the hose, there caked on coolant just above the join where the housing bolts to the engine. This means to me that it's not coming through that join, but from underneath where the hose is. Quote:
If you mean to re-replace it, it won't need it, still feels good, hasn't gone hard or anything like that. Also, those small specks of baked coolant was my fault. It's not the result of the issue at hand.
Carless
they call me Tibbo
undo the hose clamp and move it about 3mm closer to the neck of the housing.. It looks to be far enough back to actually be sitting on the flare... Make sure the hose clamp is tight, depending on the brand of clamp some of those 8-13mm ones can be duds..
and buy a new camera come and get this microwave and your console :P
#12 | |||
Adapt or perish...
Camera is in the pipeline. :P Give me a time to come get the stuff Tibbo. Except maybe not this weekend... got other stuff on.
Carless
![]() Join Date: Aug 2005
Au and BA Falcon have this fault of leaking from the Top thermo outlet where the hose attaches to. It is the Pipe Fitting coming lose in the Alloy housing. I don't think that Ford has taken much notice about ammending this? has been happening for 8 years. :(
When you are searching around for a new one, make sure that if you get an aftermarket one that it isnt like the Original. |
#14 | ||
I replaced my thermostat housing and genuine Ford it is about $29.00, I had leaks around the O ring(not me the Ford) so far so good.
cheers Bill. |
#15 | ||
good excuse to get a chrome one
#16 | ||
Adapt or perish...
Small update...
I moved the clamp towards the housing and temp is better than before (sits before N now), but I've noticed in the join that there's a coolant "seal", as in it looks like it's leaking, but it doesn't. Almost sounds like I need a new thermostat housing...
Carless
#17 | |||
Highway Taxi
I had the same problem But with a new clamp & playing with the position of the clamp the leak is finally gone. I did have to move the clamp a few times though & tighten the life out of it. Make sure you clean the housing to get a good seal.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
#18 | ||
