Old 16-07-2006, 10:19 PM   #1
XBGT_73
Default 2dr or 4dr BA/F DRAG CAR
I have a good source that a 2DR BA GT type drag car may be on the cards.As we know Brett Stevens has produced a 4 drBAGT drag car,but what are your thoughts on a 2dr?
Old 16-07-2006, 10:22 PM   #2
Melz
Melz's Avatar
So potentially which class/grouping would it belong to, super sedan or top doorslammer or anything in between????
2 door, so its a modified roofline, and maybe to come out looking like a monaro if you use your imagination????
Full metal body, or fibreglass being the next question....
Originally Posted by Jeremy Clarkson
“The Americans lecture the world on democracy and then won’t let me turn the traction control off!”
Melz is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2006, 10:43 PM   #3
XBGT_73
Top Door Slammer.Bodies are produced from a mould,either from the genuine type metal body and then modified and lengthened to Andra's guidelines.
Old 16-07-2006, 10:51 PM   #4
Melz
Melz's Avatar
I thought the ruling for TD was that they were either coupe or sedan bodies ORIGINALLY mass produced, i haven't see a 2 door mass produced BA... as much as i would like to.... but there could be some info i'm missing out on.
Old 17-07-2006, 09:33 AM   #5
supakel351
it used to be that when building a t/d you had to submit the design to ANDRA if they aproved it it became the standard all others of that model had to meet, this changes all the time. but you may notice that all the studebakers and camaros look the same etc
supakel351 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2006, 10:04 PM   #6
MIEF9640
MIEF9640's Avatar
check carpenters two car team from QLD both late models . Also check the commodore doorslammers biggest qty all made into 2Dr It is at the interpration of the national classifier and head tech . Also check tuckers pontiac in pro-stock Usa made commodore and badged as such so go figure
MIEF9640 is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2006, 09:41 PM   #7
crispy79
crispy79's Avatar
the pontiac pro stock is narrower than the monaro t/d
mk2 cortina, 2v clevo power, in build (still)
This argument that you are carrying on with is akin to shuffling deckcahirs on the Titanic.
crispy79 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2006, 08:52 AM   #8
strife
the pro stockers have different requirements they are allowed to run spec bodies from the states
doubt you would see a two door BA\F in TD look at all the hassle the brays had over the doors in the monaro
strife is offline   Reply With Quote Multi-Quote with this Post
