www.TUFFCARPARTS.com
Hi All,
Cars due for a service very shortly and while it's getting done we would like to have a tranny cooler installed. I've been looking around for them new or second hand, but I really have no idea of what I should be looking for (especially in size) and how much they're worth second hand. The car is driven quite gently, just hoping to get more life out of the gearbox! Has anyone got a tranny cooler on their AU, if so any advice would be very much appreciated!! Thanks, Justin. |
you can get them from supercheap.. made my PWR
or older falcons/fairlanes had them standard (ZL fairlane etc) but were only small
![]() Join Date: Jan 2005
Just get the biggest one you can. I have V8 rated ones on both my 6 and 8. They're about 350mm by 250mm. And only cost around $100 brand new.
![]() Join Date: Aug 2005
They can still be bought from FORD dealers NEW
#5 | |||
Walking with God
Can trasmission fluid be too cold? What would happen if that was the case?
I'm thinking here of those old Ford Trucks with the cover over the grille in Winter! Wonder if the same applied to large tranny coolers. GK
#7 | |||
As for being too cold, I guess if you fit a large enough cooler it may run cold enough to affect shift quality etc. |
#8 | |||
Highway Taxi
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
#9 | |||
Cool. Are there any side effects of having a tranny cooler fitted? Won't be going massive, was thinking around the size that you have JC.
The only side affect is that your transmission runs cooler and lasts longer & your engine runs slightly cooler and the thermos don't come on as often.
I bypassed the radiator altoghether when I fitted mine, as the brass/copper lines they use inside the radiator tend to break down over time, blocking the lines to the transmission, so most trannie places recemmoned this method. You can sdtill fit it in-line if you want, but there is little benefit in doing so. I was worried that the transmission would overheat in stop/start traffic in summer, but apparently, the transmission oilk runs at a higher temp than the radiator anyway, so when the thermos kick in to cool down the radiator when there is reduced airflow (from the car not moving), this also cools the trans cooler down, but it hasn't even reached anywhere near its critical temperature. One of mine is a K&J Thermal unit, the other is made by PWR. Both are roughly the same size, and the transmission tunnel doesn't even get warm any more. Try this link: http://www.pwr-performance.com/cooler.htm Mine is the $99 one (11" by 10") ![]()
#12 | ||
Anyone that has a ford auto from the 90,s onwards should bypass the cooler in the radiator and just run a aftermarket tranny cooler. The EF and EL had a problem of the cooler in the radiator would start to have brass flaking off and stuffing up the tranny or the cooler slowly blowing up in size till it started to leak. the AU,s have the same blowing up problem. You wont over cool the oil so the bigger the cooler the better. PWR from Supercheap are good for the money and the Drivetech ( Canadian ) ones cool very well. Never use the ones you can see the round copper pipes running back and forth through the fine alloy fins. They do not cool as well. I wouldnt use the plastic ties to put the cooler straight onto your radiator or air con condenser. Better to make brackets up so it clears by about 1cm. You can pick up cheap ones on e-bay all the time meaning you wont pay more than $30 delivered. My last one cost $16 delivered. If you cut the auto lines use a small pipe cutter and never a hack saw. You dont want little bits of steel in your auto fluid. If you go looking for the right fittings have fun they are a very odd thread.
Thanks for the advice all!! Looks like I might go with the PWR unit that JC mentioned and bypass the radiator all together. If I'm feeling brave on the day, I might even give installation a go, but I am particularly special when it comes to these things so it'll probably end up with the mechanic!!
#14 | |||
_Oo===oO_
On that note Papa Smurf, would they have been those ones as fitted to the AUIII XR8's, or aftermarket?
#15 | |||
Or is it the external engine oil cooler you are thinking of. I work at a Ford dealer & I looked up on Microcat for an external trans cooler for my AU XR a couple of weeks ago & there was no listing. We have never fitted a genuine dealer fit auto cooler because the has never been on availiable. We could have fitted hundreds of them, we are a country dealer, high proportion of customers tow. |
#16 | ||
I have been running a PWR unit in the ute ... I got the Heavy Duty unit ... slightly larger than the V8 version from memory.
And I can tell you it has made a hell of a difference (especially when towing and carrying heavy load) .. also when punishing the ute when doing courier work in Sydney ... i am finding that slippage is less ... heat is much less through the floor/tunnel ... and fluid is lasting a lot longer (not breaking down as quick). Shifting is more positive. Cold morning it takes the same time to warm up as it did previously ... still shifted fine thie morning at -5 deg ... and the ute was parked outside all night as well ... I had 3mm of ice ALL over the ute too. It's a cheap mod that extends the life of your auto ... it's well worth the money getting one. Engine temps are running the same as they did prior to getting one ... it does sit over a section of the radiator ... but that hasn't really made a difference. For all auto owners ... it is a worthy mod for transmission longevity. I run the PWR kit ... I rang Ford and they told me they don't have an oil cooler for the AU as there was no need for one ... I just laughed at the parts guy.
#17 | ||
_Oo===oO_
AUXRVIII it appeared in the brochure - extract provided.
![]() Might have been a bit of misinformation in the brochure.
#18 | ||
You can't stop the signal
Do the aftermarket coolers fit onto manuals, and is it worth putting one on?
Cheers |
#19 | |||
#20 | ||
I'm glad this thread come up, I'm planning on towing the caravan to QLD in october & I will be fitting a trans cooler along with a new radiator, looks like the PWR unit will be the way to go. I will also bypass the auto cooler in the radiator to help keep engine temp down & have a cooler auto.
#21 | ||
Thanks all, really great advice!
While we're on the topic of cooling, does anyone see any value in adding an engine oil cooler? It's just a standard 6... |
#22 | ||
AU/BA
I'm glad this post came up too. This is just what I'm after, as I was planning to fit one before summer. I have a couple of questions howerver:
1. FUQNDV8 - I had a look on ebay and couldn't find the brackets, do you have a link? 2. Had a look in the Tech Resources for how to do this installation, couldn't find, does anyone have a how-to on this? or a link to somewhere, or does the PWR kit come with instructions? 3. Does anybody know if BA's are blessed with this problem as well? Cheers Rosscoe |
#23 | ||
PWR kit comes with understandable instructions.
Ford doesn't cover the B-series warranty if an aftermarket transmission cooler is fitted. Although the Territory AWD came standard with one (the only Falcon-based I6 that has one). If it is done properly though ... I don't see there being an issue at all. AFAIK the B-series used the radiator like the A-series anyway ... so it should still be installed in a similar fashion. Just be careful with the condensor/radiator when installing the oil cooler ... don't want a damaged condensor/radiator. Oh .. if you do it yourself ... expect no skin on your knuckles afterwards ![]() The condensor is like a cheese grater.
#24 | |||
1. Ford didn't sell one. 2. You fit one under warranty and the auto goes south for ANY reason, Ford will blame the cooler .. So my ute doesn't have one and I tow cars on trailers with it. I wonder how much longer it will last? Rod. |
#25 | ||
AU/BA
JC,
Had a look at that PWR cooler site and that kit comes with 5/8" hose fittings, and I assume 5/8" hose, is that the correct size to match up with the AU pipes?, or should they be 3/8" as the EL's are. Cheers Rosscoe |
#26 | ||
There are options for different fitting sizes ... i can't remember though.
I have a pic of the kit (sitting on the floor) i fitted to my AU. ![]()
#27 | |||
#28 | ||
Nope ... it's in regards to fittings and hoses failing ... and the transmission haemoraging all of its fluid ... and the transmission running completely dry and failing.
Hence not being covered under warranty.
#29 | ||
AU/BA
Thanks for the Pic, what size fittings and hose did you use, 3/8 or 5/8?
Cheers Rosscoe |
#30 | |||
