Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 08-06-2006, 11:45 PM   #1
Redrum
Force Fed Fords
Redrum's Avatar
Default Light Weight Fly Wheel
Chris
Just had new clutch and light weight fly wheel installed. Would this be needing a re tune? Would it make much difference? Or should I just wait to I get injectors?
Jas
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2006, 10:29 AM   #2
Chris
AFF.com.au
Originally Posted by Redrum
Chris
Jas
Yes Jas - might pay to run it up and look at a datalog - a lightweight flywheel will put the load reference in a different spot, effectively moving the spark table around. The fuel wont change much though.
I may sneak a set of injectors in as well. :Up_to_som
Chris is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2006, 01:00 PM   #3
Redrum
Force Fed Fords
Redrum's Avatar
You are a champ Chris!! Got next week off, should have clutch bedded in by Thurs, Frid. I will give you a ring about then.
