Old 29-04-2006, 04:11 PM   #1
Aussie_Escort
Aussie_Escort's Avatar
Default gasket problem
Silly question
How do I replace the crankshaft timing cover & aux shaft gasket & seal on a 2 litre, cant see how to remove the toothed 'cog' on the crankshaft the timing belt pulley bolts on to.
Aussie_Escort is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2006, 06:40 PM   #2
whooligan
whooligan's Avatar
They can be a bit tight....Get a mate to hold a ring spanner on the cam pulley while you untighten the crankshaft pulley bolt. If you are on your own get a socket and a large ratchet or torque wrench if you've got one on the bottom pulley (which drives the dizzy). I use a big torque wrench and wedge it in under the chassis rail. It also helps if you have the radiator out.....Seems like a lot of work, but I like change the cam belt, water pump, thermostat housing and thermostat and sump gasket all at the same time, once a year.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2006, 09:45 PM   #3
Aussie_Escort
Thanx whooligan
The motor is on an engine stand so access is no problem, I've got the 'V' (fan belt) pulley off no probs - it's the timing belt pulley/cog on the crankshaft thats the problem, can't see how to get a gear puller on, assumming you use a gear puller, without stuffing up the alloy timing cover.
Old 01-05-2006, 09:42 AM   #4
whooligan
whooligan's Avatar
You dont need a gear puller at all???? All that holds it on is a bolt and concave washer. Remove this and give it a little tap and it should pop off.
Old 01-05-2006, 09:52 AM   #5
whooligan
whooligan's Avatar
Originally Posted by Aussie_Escort
Silly question
....Sorry, misread the question. I thought you were just replacing the sump gasket and front and rear seals.
Why do you need to remove the cog from the crankshaft? Normally you'd flip the motor, remove the whole crank and replace the upper seal with crank out.
Old 01-05-2006, 11:48 PM   #6
Aussie_Escort
whooligan its the bottom timing belt cog I'm referring to & I need to replace the seal in the alloy timing housing & as far as I can see the timing belt cog has to be off before the alloy timing housing can be removed & the seal in it replaced.
Old 02-05-2006, 09:09 PM   #7
Timmeh
Fairmont Ghia
Timmeh's Avatar
These photos may help, from when I assembled my RS2000's Pinto:
In the last photo there, the cogged wheel on the crankshaft just slids on the keyway.
Tim
Timmeh is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2006, 11:17 PM   #8
Aussie_Escort
Waaaaaaa Hooooooooo !!!!!!
After alot of gentle tap tapping-WD40-more tap tapping finally off the bloody cog came, just as well cos the seal was a hard & brittle as hell.
Thanks for the input whooligan & timmeh
