Old 24-04-2006, 06:09 PM   #1
dave_vic_ozz
Default Speedo calibration.
Ford Focus 10/2005 speedo calibration.
If I put larger rims and tyres on my focus is there an easy way to reset the speed? If the speed reads 100km but I’m doing 90km can I reset it or is this something the dealer has to do?
Dave
dave_vic_ozz is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2006, 09:03 PM   #2
pertuan
Focus on my Focus
If you get larger rims, I think the speedo would be reading lower than what you're doing. eg. Speedo reads 100... reality 110.
I think the people who can calibrate a speedo are auto-electricians which the dealer might be able to do.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 01:22 AM   #3
Zetec20
Zetec20's Avatar
you need to work out the overall wheel and tyre diameter and see how much that is out by, then you work on percentages to see if you even need to bother about it, my 20's with tyres are only 3mm larger in diameter overall
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 09:05 AM   #4
dave_vic_ozz
Yes I hear what you are saying. I'm building a new car with RWD and this fantastic Duratec motor. I will run say 18 X 7 or 18 X 8 but I want a say 60 + profile which will be larger in diameter - if they are then I want an accurate speedo. Vic has so many speed cameras.
Dave
Old 25-04-2006, 08:11 PM   #5
Zetec20
Zetec20's Avatar
hm... what gearbox are you using? wouldn't it depend on the speed sensor into the gearbox?
Old 25-04-2006, 10:47 PM   #6
dave_vic_ozz
No the speed sensor will be housed on the front wheel. I need to make brackets etc. All the drive to the rear wheels. It is where it is on the focus because it's easy.
Does anyone know what can be done with the current Duratec ECU?
Dave
Thanks for being so helpful.
Old 26-04-2006, 10:10 AM   #7
Zetec20
Zetec20's Avatar
with the current duratec ecu blackls posted in another thread that it can be flash tuned by nizpro...
