Old 16-04-2006, 05:31 PM   #1
pertuan
Focus on my Focus
Default Adjusting Power Steering.
Just out of curiosity...
With the LS Focus having Electro-Hydraulic power steering, is it possible to change any of the following:
  • Weight of steering (fully aware the XR5 has it but doable on other models?)
  • Number of turns Lock to Lock.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 06:17 PM   #2
Lagom
Turns lock to lock would require mechanical changes and the adjustable power assistance is not available on 4cyl Focuses in Australia.
Lagom is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 07:37 PM   #3
pertuan
Focus on my Focus
Bah! I was hoping I'd be able to reduce the lock to lock turn. Or at least have a play with it.
Old 16-04-2006, 07:50 PM   #4
Teki04
Clio 182 CUP!
Teki04's Avatar
Is the XR5T also Electro-hydraulic? Or just Electronic?
Steven
'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04)
Teki04 is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 07:53 PM   #5
pertuan
Focus on my Focus
According to the broucher, they are ALL Electro Hydraulic.
Old 17-04-2006, 12:53 AM   #6
BlackLS
What do you mean you want to reduce lock to lock. Electrohydralic means that a variable electric motor turns the power steering pump, not the engine. This means that the car has light steering in town (electric motor on steroids and e's) and hard onthe freeway (electric motor on weed)
Unless you physically fabricate a new steering rack, the lock to lock will not change. Ever.
Now I have thought about this problem (about making the steering a bit heavier), I was thinking about having a resistor on the line powering the power steering pump. The only problem with this is if the computer is smart. It would be easy if the computer only used road speed to determine electric motor voltage. The problem happens when if the computer uses pump pressure vs road speed. If this is so more than likely, then the computer will see the pressure being low, and increase pump speed to suit. This will make the resistor next to useless.
Old 17-04-2006, 08:46 AM   #7
pertuan
Focus on my Focus
I was just curious if the lock to lock thing can be done. Would be cool though to have say 1.5 turns lock to lock. How easy would parallel parking be then? hehe.
That resistor idea sounds interesting. You could hook it up to buttons and mount them on the center console where the Euro Foci have their ESP buttons.
Old 17-04-2006, 08:55 AM   #8
BlackLS
Now thats an idea. I find it funny only 1 of 4 switches are used there!
Ill suss out how it actually works and go from there
Old 17-04-2006, 11:38 AM   #9
pertuan
Focus on my Focus
The defroster button could be moved to one side. Then you could have multiple settings...
- Sports
- Normal
- and "Is this thing even connected?!?" hehe
Old 17-04-2006, 12:06 PM   #10
Lagom
BMW has their Active Steering system, which actually adjusts the steering ratio based on driving conditions.
Old 19-04-2006, 11:56 AM   #11
dave_vic_ozz
go to the wreching Focus link and you can get the bits to play with real cheap. The pump is in a few pieces now but the rack is intact.
dave_vic_ozz is offline   Reply With Quote Multi-Quote with this Post
