Old 12-04-2006, 08:14 PM   #1
Smoke Pursuit
Default Ls Focus - Headlights Out Of Position??
Had the right hand headlight replaced in the focus, it was out of allignment pointing way down towards the ground now, went to go and adjust it but theres no way of adjusting them??? I even pulled the headlight out of the car to check (you have to neways to get to the back of it), and there was nothing!
Before anyone says anything, the LS Focus CL does not come with the headlight adjustment on the dash, so therefore we have a high left headlight and low right.. I even looked at the left hand one and broke the ИИИИing CLIP on the shield on the back off it, hopefully they will replace that under warranty and i dont have to buy an entire new headlight.
Cant wait for this thing to do its time and be replaced by another mazda, true dissapointment in more respects then one.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 08:25 PM   #2
pertuan
Focus on my Focus
Doesnt the manual have instructions on how to adjust it? I think I remember seeing it in there.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 08:29 PM   #3
Smoke Pursuit
Please find and tell me where, ive looked thru it, all ive found is the adjustment ont he dash which our car doesnt have or the ИИИИin way to remove headlight globes.. Nothing about how to re adjust the headlight, ИИИИs me how the car can even be ADR compliant...
Old 12-04-2006, 08:39 PM   #4
pertuan
Focus on my Focus
OK, I just went down to the garage and looked at the manual. You're right... theres nothing there about adjusting the headlights... my bad.
Old 12-04-2006, 08:42 PM   #5
Smoke Pursuit
Thanks buddy for making sure.
Talk about ИИИИed off, i need the headlights fixed on this car for tomorrow as its going south late tomorrow nite, properly alligned headlights are obviously a must for us and for on coming traffic, can't believe it has no adjustment to be found.
Old 12-04-2006, 08:53 PM   #6
pertuan
Focus on my Focus
If worse comes to worse, I guess you could put spacers in the mounts for the meantime.
Old 12-04-2006, 09:11 PM   #7
zetec
Zoom Zoom
zetec's Avatar
Dealer.
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 09:12 PM   #8
Smoke Pursuit
No time left for dealer.. Car is packed, i have to work tomorrow till 9 tomorrow nite, only other option is take my Car, but we have issues parking it at the place we are going to...
Why there is no way of adjusting them Ill never know :(
Old 12-04-2006, 09:23 PM   #9
zetec
Zoom Zoom
zetec's Avatar
Put a fat chick on one side of the car to level it out...
2012 Mazda3 MPS
Old 13-04-2006, 12:43 AM   #10
amlohac
amlohac's Avatar
while we are on the topic of headlights does anyone have the problem of one high beam light being dimmer than the other one? Now before you tell me to change the globes and various other things ive already tried. Put new globes in, put the old one back in adjusted the little screw things on the head light (did sweet ИИИИ all mind you)
So if anyone has ideas that would be awsome, also has anyone got some ideas (brands prices etc) for new brighter globe for the zetec (03 one not the new one)?
amlohac is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 06:47 AM   #11
melbzetec
Old enough to know better
melbzetec's Avatar
Without stating the obvious, the right hand light IS supposed to be lower than the left. Designed so the light isn't in the eyes of the driver coming the other way (RHS in Australia). In otherwords, the headlight is higher on the footpath side than the drivers side.
Hard to comment further without seeing the problem, but maybe you're trying to adjust something that shouldn't be adjusted.
On dash headlight alignment, at least in the LR Focus, adjusts both headlights at once anyway, so wouldn't help if it was there
Old 14-04-2006, 01:54 AM   #12
BlackLS
If i remember correctly (I'm not going outside in computer clothes) There are adjustment dials/grubscrews sitting on the top of the headlight. There white and I think you use an allan key to adjust it.
Old 14-04-2006, 05:53 PM   #13
amlohac
amlohac's Avatar
Yeah i have used those, they do very little at all. Still cant work out the dimmer high beam globe though, very annoying.
Old 14-04-2006, 05:58 PM   #14
LUXO_8
windsor user
not being a smartarse, but thats just due to the perspective.....
sit on the passenger side of your car and you'll say they're the oposite
yes, they are the adjustment for the reflector , the geared ratio isnt 1:1, so it will seem as though they arent adjusting...
use an allen key type bit on a fairly slow cordless drill........and dont over adjust them or else you'll stuff the adjustment.
my reccomendation is to take it to a panel shop or electrition to do the adjustmeny for you.....
Old 15-04-2006, 01:56 AM   #15
BlackLS
I stripped the thread off the adjustment knob of our my parents old EF the second day they had it in 97. :S
A garage that does roadworthies should be able to adjust it as well to suit ADRs beam direction height
Old 16-04-2006, 09:13 PM   #16
amlohac
amlohac's Avatar
No its not perspective. I was told while driving up to someone at night with the highs on that one globe was dim. I told them the same thing "just the way you are lookin at it dude". But when i sit in the car and have the lights pointing at something that reflects the image of the car (like a window) the passenger light IS dimmer, and it never used to be.
Im not sure when exactly it happened, but i hit a bird and it blew out my indicator on that side (big ИИИИing bird). Im assuming it could have something to do with that, if the bird hit it hard enought to blow a globe maybe it knocked the high beam relfector thing right out of place?
Its not important cos the light still works its just a masive pain in the crack.
