Old 28-02-2005, 07:37 PM   #1
Timmeh
Fairmont Ghia
Timmeh's Avatar
Default Mk II RS2000 4 speed info
A quick question - if I am re-building the RS2000 2L for big horsepower - think wild on boost but not stupid horsepower hero style - how well will the 4 speed manual stand up (if at all?).
Have plenty of experience and technical help with the engine and boost part, but I have no experience with the RS2000 gearbox, and while it's been great for the standard output, I get the feeling it won't last 5 seconds when the engine goes back in, same with the std diff.
Any experience would be appreciated.
Tim
Timmeh is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2005, 08:01 PM   #2
Perana
Perana's Avatar
You are right tim. The standard gearbox is good for only a bit more than standard probably up to 170HP and definatly wont handle the torque of a turbo motor for very long. The diff centre is about the same and it seems axles arent a whole lot better, you can get a Quaife centre and axles which are much stronger but i think in your case a complete different stronger diff would be more suitable.
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2005, 11:31 PM   #3
kiwikid
have you seen my marbles?
kiwikid's Avatar
original 4 speeds are tough as nails but if you dont like the massive jump from 1st to 2nd, want a bit better economy and better pick up go a sierra 5 speed, stronger and much better than the standard 3.56:1/1.97:1/1.37:1/1.00:1 ratios...
comfortably numb...
kiwikid is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2005, 11:44 PM   #4
XP6
Formerly ST170ish
XP6's Avatar
http://classicford.mine.nu/forum/default.asp
Check these guys out they'll have all the info you'll ever need.
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2005, 11:55 PM   #5
Timmeh
Fairmont Ghia
Timmeh's Avatar
Thanks guys...
Tim
Old 01-03-2005, 12:04 AM   #6
kiwikid
kiwikid's Avatar
im a member have been for a while... anything you want to know about an esky will be there
comfortably numb...
Old 01-03-2005, 12:44 PM   #7
Perana
Perana's Avatar
Unless its a sierra cosworth box its basically just the old four speeder with an overdriven 5th gear so 1st to 4th are the same ratios... and is actually weaker becuase like the T5 5th gear can get starved of oil because its in the extension housing..
Old 01-03-2005, 08:10 PM   #8
rag top
rag top's Avatar
What about the old straight cut gear set, refered to as a "rocket" box??
I thought that was a bit stronger than the standard cluster. Bit pricey though.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2005, 08:22 PM   #9
Perana
Perana's Avatar
Yeah the Rocket is much stronger but as you say it is fairly pricey... There is also gear kits available from Quaife in various ratios ,straight cut or helical cut, normal, dog or sequential shift too.. but they are also fairly pricey
Old 01-03-2005, 08:37 PM   #10
rag top
rag top's Avatar
Sounds like it's going to be expensive what ever option is taken...
Tranny tunnel mods could be on the cards...
Does the supra box fit or are lots of mods required to fit that?
Current Rides:
Old 01-03-2005, 09:22 PM   #11
Perana
Perana's Avatar
Supra box can be fitted... not sure on how difficult etc though...
Old 02-03-2005, 10:50 AM   #12
rag top
rag top's Avatar
A mate used the supra box on his mk1 esky turbo car. Unfortunately, it was originally an auto so I don't know how difficult it would be to fit a manual tranny tunnel.
Current Rides:
Old 02-03-2005, 04:49 PM   #13
kiwikid
kiwikid's Avatar
i was reffering to the type 9 out of the pinto powered sierra's.......
comfortably numb...
Old 02-03-2005, 05:44 PM   #14
Perana
Perana's Avatar
Thats the box im reffering to :P
Old 05-03-2005, 03:11 PM   #15
T3man
T3man's Avatar
The original four speed will handle about 50% more torque easy. There is no real benefit to the Sierra box as far as ratios are concerned. I had a steel case Celica box in mine and now have the alloy Supra box. Much better ratios in the Toy boxes and very strong in the Escort even with a turbo. There is no problem fitting them up. You need a new crossmember which I made myself. Jeff Dellow Automotive in Sydney have full conversion kits including clutch plate, speedo cable, yoke etc etc.
