Old 30-03-2006, 03:14 AM   #1
91A
Default Headlamp globe changing on AU2
I have to change the main headlamp globe on my AU2. Various handbooks say
pull the electrical plug whilst others say squeeze the sides of the plug and then pull. Being 500 years old, I do not seem to have the strength to squeeze and pull at the same time.
Which is right?
Russell
91A is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2006, 04:37 AM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
YEs, squeeze the tabs (at 3 and 9 o'clock) and then pull the connector off.. If you are really stuck or the connector is being stubborn undo the earth retainer clip and lift the bulb out where you can see it.. Sometimes you need to wedge a little flatblade screwdriver in between the bulb to level it out..
