24-03-2006, 01:58 PM | #1 | ||
Motorsport Guru
Well, not exactly. Try 93.2kw. This is the figure quoted in AutoAction#1182 in an article about the new Fiesta engine fitted to the 2006 Formula Fords.
Not a bad increase in power over the standard figure!
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System. Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle. Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust. Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus. |
24-03-2006, 02:08 PM | #2 | ||
Da Shifty One
Specs taken from Formula Ford Website. Engine can be ordered for $10000 :thebirds:
AUSTRALIAN NATIONAL FORMULA FORD 2006 FORD FIESTA ENGINE SPECIFICATIONS ENGINE 1600cc, 100ps DOHC, Ford Fiesta engine, producing around 125bhp, sealed on cylinder head & front & rear crankshaft seal covers AIR FILTER Control K&N Filter, supplied with engine FLYWHEEL Standard, as supplied with engine CLUTCH COVER Standard, as supplied with engine CLUTCH PLATE Control, supplied with engine ECU MoTeC M4, control, pre-set to FFA Specs. Supplied with engine WIRING LOOM GR Motorsport control engine loom, supplied with engine OIL SCAVENGE PUMP Control, supplied with engine INLET MANIFOLD Control, supplied with engine THROTTLE BODY Control, supplied with engine ALTERNATOR Control, supplied with engine SUMP Control Pace Sump EXHAUST Control Collector, pipes to meet specified control Dimensions COOLING SYSTEM Free, within current regulations FUEL & OIL PRESSURE SENSORS Control parts, available through FFA or from external suppliers MAP SENSOR Control part, available through FFA or from external suppliers IGNITION MODULE Control part, available through FFA or from external suppliers AIR & WATER TEMP. SENSORS Control part, available through FFA or from external suppliers THROTTLE POSITION SENSOR Control part, available through FFA or from external suppliers
2013 Ford Fiesta ST - Frozen White - AU 0072/XXXX
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade - |
24-03-2006, 02:08 PM | #3 | ||
mmmn be nice!
GGR | SCT | Tein | Samco | Whiteline | Mongoose | Forge
24-03-2006, 03:19 PM | #4 | ||
Candy White GTI
YUM ! i wonder what kinda torque it would have.
Volkswagen GTI Polo. Candy White, Anthracite heated Sports leather seats w/ Red stitching.Tinted Windows, Eibach Pro-Kit springs,Whiteline Front/Rear adjustable sway bars,Cupra R intake, Forge Turbo Inlet pipe,BMC panel filter, APR stage one flash, Dunlop SP sport MAXX, Forge Polished upper front strut brace. 3'' downpipe and highflow cat Loads of fun : |
25-03-2006, 11:22 AM | #5 | ||
Get in the van!
Just heard those new Formula Fords yesterday at the Clipsal 500. God they sound sweet! Makes a big difference from the old Kent motors they've been running for donkey's years.
The Dad Bus (TM): 2004 BA XT Wagon, soon to be set up as a camper and tourer. |
25-03-2006, 07:23 PM | #6 | ||
Clio 182 CUP!
Come on - I'm pulling 100kw at the wheels :P
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
26-03-2006, 12:46 AM | #7 | |||
Get in the van!
26-03-2006, 10:44 AM | #8 | ||
Motorsport Guru
Mista Fiesta,
Thanks for info on the engine specs. Very interesting. BTW, I was over at my local Ford Dealer and chatting with a mate there and told that if I was interested I could get a COSWORTH Engine for my Foci for about $30k. Not sure if this figure sounds accurate but if I had a "lazy $30k lying around" you know what I'd do!
