24-03-2006, 11:23 AM | #1 | ||
GDay fellas,
Last night i gave the beast a little stick off the line and shortly after i could sense a burning smell.... next thing....my battery light comes on.....great..ive blown my alternator... next thing thats lit up was my temp light.....needle in red.....great there gos the head i pull over and let the car idle for 10 mins then turn it off.....coolant was boiling but not leaking anywhere exsessively...i could see seapage in a few places from the rocker gasket...ok no problem.....i inspected the block this morning and i can't see any stains nor any leakage from the head... check my alternator to discover the belt missing... im really confused....it over heated really quickly and its not losing much fluid any suggestions?? next drama is to what i should do.... my main concern is the head.....if its the head im going to either a) get a tickford head from an el b)whack in an el xr8/v8 engine......... how easy is a v8 conversion on the ebs? any help would be appreciated cheers |
24-03-2006, 11:29 AM | #2 | ||
you cooked it good!
time for a fresh engine! |
24-03-2006, 11:33 AM | #3 | ||
come on mate give me somthing to work with other than stating the obvious
24-03-2006, 11:35 AM | #4 | ||
FPV GT Owner!!!
Ive had mine cooked plenty of times and it is still fine(still good bores and compression)....
Dont worry about it, next time it overheats however turn it off lol, dont let it idle. The reason it overheated is because the water pump was not flowing the coolant through the system. So the coolant in the radiator stayed nice and cool while the rest of the coolant in the motor started to cook. Fix the belt, drain and reflush coolant and oil and do a compression test and post it here. If you still have good compression Dont worry about it.
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
24-03-2006, 11:40 AM | #5 | ||
BLOWN 383 CHEV OWNER
sounds like you got yourself a problem, go the V8 route.
24-03-2006, 11:43 AM | #6 | ||
FPV GT Owner!!!
There would have been a slow leak out of overflow pipe... That would have been the steam you were sensing.
24-03-2006, 11:46 AM | #7 | ||
well i let it idle out of fear of heat soak...
well that makes more sense now why it heated up so quickly...... if compression is good then all i'll need is a rocker gasket sorta hope its rooted tho....wanna v8 ...was gonna go cam and chip soon...so if i add that cost to the cost of a new head...i should be in business for interests sake what are the main points of dropping in a v8? |
24-03-2006, 11:48 AM | #8 | ||
Parts bin special
My parents had that happen to their EBII and after about 30-40,000kms since then, it still runs beautifully. Besides a new belt, it didn't need any work. Those fan/alternator belts are a problem in the e-series. They are very thin, so they're not designed to last.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
24-03-2006, 11:51 AM | #9 | ||
24-03-2006, 12:22 PM | #10 | ||
hibernating
Yes if the alternator belt comes off it means the waterpump isn't turning and it will overheat... It happened to me once before. The engine was still fine when it happened to me. Worst case is that you may of done a head gasket or warped the head... its not really that big of a job.
24-03-2006, 12:25 PM | #11 | ||
yeah well its got oxidisation around the rocker gasket
i know there shouldn't be coolant comming from there which may mean something in the heads ИИИИed..yes or no? |
24-03-2006, 12:27 PM | #12 | ||
bugger just realised that the xr6 engine is an AU...they fit wityh a bit of grinding hey?
24-03-2006, 02:24 PM | #13 | ||
If the needle is in the red, why did u let it idle for 10mins???
Brent
EB1 Falcon Wagon 3.9L Multipoint with 5 speed manual Pacemaker extractors & 2.5" Redback exhaust Tickford Head and Wade 1004 cam HP4 Chiptorque chip and XH intake 1992 DC LTD
5LTR DUEL FUEL |
24-03-2006, 02:28 PM | #14 | ||
i was worried about it heat soaking
24-03-2006, 03:10 PM | #15 | ||
Windsor Man!
I've never heard the term heat soking, but I do know that if the engine is hot, leave it idling so the water flows and cools it down, unless of course the water pump isn't turning. You weren't to know the pump wasn't turning, although, you could've popped the bonnet and had a looksee.
AS for a V8 conversion, buy yourself an EB with an 8 in it. Unless you wanna buy the 5.0 that 347stroker has for sale. The AU motor isn't quite worth 1g and your engine bay will need a couple of mods to fit it, but it will go in quite nicely.
Wife's car - BA XT Wagon - Lowm shiney wheels, dark tint, no bottom half of front bar, faded paint :/ My Car - 93 Diesel Lux - not as fast but more reliable than her falcon! |
24-03-2006, 03:39 PM | #16 | ||
well theres no point having an e series 8 except for the noise me thinks
but for interests sake how much is he selling it? i don't really know what im gonna do i will start by putting a new belt on and see how the gaskets hold up new motor/head is only the action ill take if the heads stuffed yeah i didn't even think of the water pump waity.....and it was dark...couldn't see anything |
24-03-2006, 03:47 PM | #17 | ||
that belt runs the alternater, water pump and clutch fan so if it snaps you're in trouble. I have cooked my car plenty of times.
24-03-2006, 03:49 PM | #18 | ||
yeah its such a crap thing to happen
24-03-2006, 03:55 PM | #19 | ||
Performance moderator
Any one with 1/2 brain would know that if alternator light comes on ..Chances are the belt has come off...
Just replace belt...Then if you are really worried just replace head bolts [$45] with new ones.... In some cases an overheated engine can run better when issues have been fixed..If there was still steam coming out of it ?? Chances are the engine is still o/k... Replace thermostat they often throw the towel in after an episode like this...
24-03-2006, 04:00 PM | #20 | ||
yeah well i thought i cooked it (alternator)...didn't think of it breaking...maybe i don't even have half a brain...
it didn't see any steam....i just slowy released the coolant cap a little at a time then back on 5 or 6 times over 10 mins..... ill replace the thermostat for sure |
24-03-2006, 04:02 PM | #21 | ||
i drove it home 2
had to stop twice tho....would pull over before it got a cm or 2 before the red it sounded fine and drove normally |
24-03-2006, 04:07 PM | #22 | ||
But hang on, u say the overheat light come on the dash? in my experience with broken belts is that once the guage hits the red, the light comes on. Ud have to run the engine awhile before u did any damage. How long was the light on??? Or didnt u notice it straight away? Chances are your engine will be fine!!
Brent
5LTR DUEL FUEL |
24-03-2006, 04:13 PM | #23 | ||
the battery light came on first
then the temp about 3 mins later.....thats when i double checked with the temp gauge pulled straight over waited half an hour...drive it a few k's...pulled over before the light came on......waited half an hour....drove a few k's before the light came on...waited another half an hour and got it home just as the light came on as i said before nothing felt wrong with it...revved and sounded fine(not that i revved it much) |
24-03-2006, 04:20 PM | #24 | ||
yeah, it would be OK... mine hit red when my belt broke... stopped straight away..
Wasnt even steaming so i replaced the belt and she is still going strong today. Wouldnt worry bout the new engine unless its what u really want to do in which case it makes for a good excuse! Brent
5LTR DUEL FUEL |
24-03-2006, 04:28 PM | #25 | ||
yeah well i was gonna be doing a cam soon anyway so thats the rocker gasket fixed
my concern is the head....coollant shouldn't be comming from the rocker right>? |
27-03-2006, 12:24 AM | #26 | ||
FPV GT Owner!!!
I really think you are getting something wrong... There is no way clear/clean coolant will come out of the rocker cover...
It would be a milky substance if it was.. I would look at the gasket where the thermostat housing is... Maybe its spraying upwards and the pressure caused by no movement of the coolant broke a few gaskets which could be the case.. where is the leak coming from?? (What area of the rocker gasket?)
27-03-2006, 01:16 AM | #27 | ||
[EBGLT]
No coolant should not be coming out of the rocker sounds like you have cooked it mate! If you turned it off in this first place you may have saved it if your lucky you may not have cooked it but it sounds like it!!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
27-03-2006, 03:25 AM | #28 | ||
[ 5L ]
its common sense when it gets to the red u turn your car off and not drive it home
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
