Old 21-03-2006, 09:03 PM   #1
hobo
Monster Burreuto
hobo's Avatar
Default 3.45 LSD for an EA
can somebody tell me if a 3.45 LSD from an EF/EL will fit in an EA? if the whole housing wont go in, can i use the center and axles from an EF/EL?
I PITY THE FOOL :ticking:
hobo is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 11:30 PM   #2
Brent79
Yep, as far as i know, you can transplant the centre and axels...
Brent
EB1 Falcon Wagon
3.9L Multipoint with 5 speed manual
Pacemaker extractors & 2.5" Redback exhaust
Tickford Head and Wade 1004 cam
HP4 Chiptorque chip and XH intake
1992 DC LTD
5LTR DUEL FUEL
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 08:38 AM   #3
mcflux
mcflux's Avatar
If you swap the whole diff over, you have to consider that the EF-ELs have a different handbrake cable mounting to the EA-ED diffs. So swapping the gears themselves would be best
Old 22-03-2006, 10:23 AM   #4
Rmyers
Does Steve have a car?
Rmyers's Avatar
Also the lower trailing arms are different. The mountng point on the diff side is alot wider so you will need to get EF trailing arms put in or get EF bushes pressed into the EA arms. So yeah it's better to get the gears and axels swapped over rather than the whole diff housing etc...
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 04:58 PM   #5
hobo
Monster Burreuto
hobo's Avatar
ok, thats very good, wasnt sure if the axles would go in ok. is it a simple job of taking out the axles and centre and bolting in it back together with the new stuff? or is there shimming/adjustments required? how much would i be looking at to get a diff place to do it? thanks
Old 22-03-2006, 09:34 PM   #6
EF_Frmnt
EF_Frmnt's Avatar
5-700 for a good place to do it.. im not sure about the 2 pinion to 4 pinion i think it will be fine if you are converting the centre axles and gears
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 02:45 AM   #7
24K EA
Tu Toned Ghia
24K EA's Avatar
can you change diff gears your self? is it hard?
24K EA is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 01:33 PM   #8
mcflux
mcflux's Avatar
Dunno where you went, mine cost ~$170.
Well, $336 for two diffs at once that is, the 2nd diff being a mate's which is under his Falcon now.
