Old 03-01-2006, 05:06 PM   #1
laybourne
Default AU courtesy lights problem
I have a problem with the courtesy lights not turning on when the car is unlocked. They all work fine with the manual switch, but are not automatic. You know how most cars have a plunger on the door frame to turn inside lights on, well I guess the AU's run on the computer somehow. Is this a correct assumption? Can't quite down-load diagrams as we live rural, and the speed is non-existant for files like these.
Old 03-01-2006, 06:23 PM   #2
mattbl
mattbl's Avatar
Hi
You don't say which model you have but firstly check the fuses. There are two that run the courtesy lights positions 10 (5 amp) & 11 (15 amp).
Yes you are correct the courtesy lights are controlled by the BEM (body computer) located behind the centre console, but I'd be going for the easy things first such as fuses or a globe that is out and possibly shorting.
2006 BF Egas XR6 Ute. Bone stock - Sorry Fellas I've had a set of King Springs in the garage for 12 months who knows when I'll get around to putting them on :
mattbl is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 09:44 AM   #3
laybourne
..Thanks. Have checked everything and fuse OK. The boot light won't go for some reason. Someone said that the boot light is the computer circuit lamp (??) and the car won't start without it. Surely not. I wonder if it is related to the courtesy lights.
Old 04-01-2006, 01:24 PM   #4
mattbl
mattbl's Avatar
Yep the luggage compartment lamp is in the courtesy light circuit.
Maybe start there???
