Old 02-01-2006, 01:46 AM   #1
elusiverunner
elusiverunner's Avatar
Question Is it Hot or What ?
I have a 1991 EB series I Fairmont Ghia. On 03/05/2005 I had the car retrofitted with the newer 134A airconditioning system and regassed. I have used the airconditioning twice since then. The first time was just before Christmas and the air being pumped in the car was less than cool. There was also a hissing sound coming from, what appeared to be under the dash on the front passenger side.
The second time I used the airconditioning was yesterday 01/01/2006 at about 6:50 pm. The car had been sitting in the garage all day. I drove about half way to work - some 10 kilometres when the air just became unbearable so I turned the airconditioning on closed up the windows. I was unimpressed as the air coming from the vents was hotter than the outside temperature and the hissing sound started again.
Now the doors, etc on the normal ventilation system are all in order - that is fresh air and so on, so I don't think there is a leak in the system. I have also run several diagnostic system checks and the climate control passes with no errors showing.
With all this in mind any ideas or suggestions you have will be most appreciated. : :1syellow1
elusiverunner is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 02:01 AM   #2
John_LS1
could only be a leak, or your pump has crapped itself?
Old 02-01-2006, 02:12 AM   #3
InitialD
Low and Loud
InitialD's Avatar
that hissing kinda sound from the heaterbox is normal. My mums EA GHIA that was regassed does it.
No idea why it isnt working thou, take the car back to the AC place
Old 02-01-2006, 02:16 AM   #4
fairmont1998
fairmont1998's Avatar
Loud hissing from the TX valve is a good sign the system is low on refrigerant, and therefore there is a possible leak.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 09:06 AM   #5
OZ-E 5.0L
get some uv die put in the system & find the leak.. also follow all the ac piping & look for oil /wet stains ..get some 1 to chech ur presures & cheak that the heater flap is all the way to the stop ..
OZ-E 5.0L is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 11:38 PM   #6
snypereb
[EBGLT]
snypereb's Avatar
Did it come with a warrantee on the a/c stuff take it back mate?!!!
Shaun
[EBGLT]
