Hey all,
Just a quick question. I picked up a motor for my EB the other day it's a 3.9, anyways on the front of the motor it has 87DA-6059-AA. I had a look at the motor in my EB (series 2, pre smart lock) and it also has 87DA-6059-AA on the front of the block, the head is a 91AA. I found this a bit strange as it is supposedly a 4.0. ![]() Did they have the same code for the 3.9 and 4.0 blocks ? Or has my car been stooged from the factory. ![]() ![]() |
#2 | |||
Id say since both 3.9's and 4.0's come from the same casting (I believe) you probably havnt been stooged. A 4.0 is just a 3.9 that has been slightly bored out.
[ 5L ]
im not sure on this but someone told me that is was just the heads that were different but im not sure on this for sure
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
someone with an EB2 wanna have a look at the front of the block and tell me what numbers are printed on it ? it's just under the idler pulley.
mine says 91AA
Kurucu Performance
maybe the engines headgasket has been changed and at the same time the head may have been replaced...
174rwkW N/A I6 Kurucu Performance Enhanced... Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph Now With EL XR6 Engine & ECU & 3.7 Gears Www.KurucuPerformance.Vze.Com |
but's it's suppossed to be a 4.0 It doesn't really faze me, the motor is stuffed anyways, but i just wanna know if the EB 4.0 motors were 87DA-6059-AA. Maybe cause mine is an Early EB2 they used the same numbers.
EBFalcs - I think you were lookin at the head, mine is 91 AA too, i'm interetes ion the numbers on the fron of the block above the Balancer. |
Gunna girlie-man
the two engines also have different power.
*3.9L multi-point 6 cyl Bore and stroke: 93 x 99 mm Power: 139kW at 4250rpm Torque: 338Nm at 3500rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC IV fuel injection Compression ratio: 8.8:1 4.0L 6 cyl (Series II) Bore and stroke: 92 x 99 mm Power: 148kW at 4500rpm Torque: 348Nm at 3750rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC IV fuel injection Compression ratio: 8.8:1 sorry bout that, just had to confuse the situation!!! ![]()
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
Regular Bum
gtho fan how can the 4ltr have a smaller bore than the 3.9?
I thought the differnce was just the bore??? THanks Matt |
Gunna girlie-man
i got the info off this website!!!
http://www.geocities.com/falconfacts.../ebfalcon.html check it out. every falcon made, sweet website, shows all stats
Custom user title
i thikn u will find that that part no is just the one of the timing cover mabie???.. or is that the actualy number CAST into the block(steel)
#12 | ||
yeah it's on the timing cover lol. So it's just a the part No for the timing case, that would make sence. Thanks injected!
Custom user title
THe 3.9 blocks are slighly narrowier where the oil gallery is on the side, its a visual differnece,
#14 | ||
EA and EB engines shared the same timing cover 87DA as mentioned. only ED got the later 91 DA timing cover with EF style top gasket ;)
#15 | ||
![]() Join Date: Jan 2005
The block's part number is locatad on the bottom of the exhaust side, just above where the sump bolts up.
Good to see you got a new motor. How much was it? Is it stock or is there some work done to it or something? Sundeep
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
