As in title. Can I bolt a windsor v8 starte motor to a standard 2 bolt clevo bellhousing. I realise that the windsors have a three bolt arrangement but I was thinking that if 2 out of the three lined up and the starter gear meshed properly then maybe I could utilise it?
If not does any one know where I could chase up a clevo starter motor that when changed to passenger side will have the solenoid facing upwards instead of down?
project #1: Ea series1 Spac conversion to straight gas; 351Cleveland; T5; EB dash; sunroof and more as I get to them. :evilsasmo Fully road legal and cruising in QLD!! --------------------------------------------------- Happy dealings with; PROTD, !gn!t!on, Big_waity,Phongus |
maybe a Q for the general tech boys, you think.
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG. |
Great question. I need to know the same thing. They are avalible from "Castle main rod shop" but at $400.+ for a geared hi-torque starter.
Early clevland and windsor starters are the same(to the best of my knowlage) but the 5.0 winsor is not compatible with a clevo for sure. David |
Custom user title
mate u can use a 4.0 6 cyl stater on a clevo a bit of grinding is required so the ring gear misses the starter body. but once set up its quite a good gear reduction starter
is 3.9 ea starter the same as the 4.0 starter? I ask this I have a spare one laying around somewhere and hadn't thought to check it out.
more posting less lurking
The 3.9 starter is not the same as the 4.0 starter as I believe it is not gear reduction, but still has the same bolt pattern. Certainly worth trying if you have one sitting around
BA XR8 Devil R - SY Territory TX AWD - MQ Nissan Patrol 302c - GQ Nissan Patrol |
yep they're the same physicaly.
Custom user title
NO there not the EA starter is massive compaired to the 4.0 starter...
no worries I'll hunt up a 4.0 starter...Shouldn't be too hard or expensive to track one down......hint hint ??
let us know how you go and if it all fits up ok. David
will let all know how it goes as I progress. Will post updates in my ea into cleveland thread....
#12 | ||
Custom user title
you need to mod them a little.. and also watch the steering box arm as it can be close to the starter depending weather its p/s or manual box
isn't the 4 litre starter usually mounted on the passenger side? this then means orientation of the solenoid should be upward hopefully.
#14 | ||
i'm positive the 3.9 starter is the same, i have a 3.9 and 4.0 and have changed the clutch in both recently and was positive they were the same. I guess my eyes decieved me.
#15 | ||
Custom user title
ones a gear reduction one. and ones a big old fat one like an XF starter
