Old 16-10-2005, 03:07 PM   #1
Orbit
Resident Nyctophobic!!
Orbit's Avatar
Default ALtinator
Whats the standard altinator in the AU3?
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2005, 05:33 PM   #2
SPLINTER
AU2 XR8 PURSUIT UTE
SPLINTER's Avatar
The standard alternator is usually a Motorcraft but some had a Mitsubishi unit and they differ between the 6 and 8cyl. It should be a birdcage style. I sell these units and the 6cyl is a MXA283 but the 8 is different. The misti one is usually the same but you need to change the plug.
If you would like more info let me know.
SPLINTER is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2005, 09:25 PM   #3
Orbit
Orbit's Avatar
what are they rated to?
i have a 6cly on gas.
Old 17-10-2005, 02:47 AM   #4
Mechan1k
Mechan1k's Avatar
I had to replace mine not too long ago ... cos power steer fluid was leaking into it and it slowly killed it.
Thank God NRMA comes out to you and replaces them on the side of the road for you ... 30 min and your back on your way again (suited me cos i was doing courier work at the time and stuck on the side of the road with deliveries onboard).
Old 17-10-2005, 12:44 PM   #5
Sourbastard
Contributing Member
Sourbastard's Avatar
How much did they slug you for that?
1965 XP Falcon Deluxe Sedan
2003 BA Fairlane G220
Old 18-10-2005, 11:04 AM   #6
SPLINTER
AU2 XR8 PURSUIT UTE
SPLINTER's Avatar
The Mistubishi replacment units are 110amp.
Do you have a photo of your one or some numbers off the unit?
Old 18-10-2005, 05:16 PM   #7
Orbit
Orbit's Avatar
not that i can get on to the net.
but it's just what ever was stock when the car was made.
Old 18-10-2005, 06:22 PM   #8
SPLINTER
AU2 XR8 PURSUIT UTE
SPLINTER's Avatar
I have attached two pictures with some the info on both the au 6cyl alternators i stock. I hope this helps you
:voldar02:
Old 19-10-2005, 03:08 PM   #9
Orbit
Orbit's Avatar
thanks, mine the 110amp.
Old 20-10-2005, 12:38 PM   #10
Mechan1k
Mechan1k's Avatar
$300 ... but it got me going again with little downtime.
I couldn't wait for the ute to be towed ... then stay overnight in an auto electricians before they looked at it ... and then have another day off the road while they fix it (then try and get from home over to where the auto electrician was .... ie: other side of Sydney).
I thought $300 inc. labour was reasonable for a roadside replacement with warranty.
