Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > XR6 & XR8 Club of Queensland > XR Club of Qld Discussions
Old 30-09-2005, 05:31 PM   #1
xr6er
Default Airbag light p*@#ing me off
The airbag light is staying on, first it flashes a couple of times then goes out, then flashes again then goes out, then it stay on all the time, and the bloody horn does not work. HELP!!!
Old 30-09-2005, 05:40 PM   #2
BlackLS
Check the fuse?
You may find under the drivers visor some info...
Old 30-09-2005, 06:05 PM   #3
The Dok
The Dok's Avatar
Horn not working indicates the clockspring ***'y, usually as a result of a light hit in the front or an impact to the steering wheel. Check the airbag fuse first however, it's in the fusebox, @10amp from memory.
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2005, 09:13 PM   #4
fairmont1998
fairmont1998's Avatar
If you count the flashes it will give a diagnostic code which will help us too.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2005, 09:34 PM   #5
GOLDIE
Where do you live as i own a workshop on the gold coast and have the gear to test all this pm me if you need me to help.
Ian
Acid rush txr6,5.1 surround sound,350 rwkw's,major interior trim work.
GOLDIE is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 10:48 AM   #6
XR6TU
Addicted to BOOST!!
XR6TU's Avatar
Heya Ian :
Yep he knows his stuff, do yourself a favour. Go see him.
MANDARIN XR6 TURBO Ute - 5 Speed Manual, 18 " Rims, 6 stacker CD,
SS Inductions CAI, K&N Filter, FPV Pedals, MOMO Gear Knob.
GO THE TURBO!!!
XR6TU is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 10:56 AM   #7
xr8ute
Back on the road
xr8ute's Avatar
clockspring most likely
Old 05-10-2005, 12:16 PM   #8
rolling jaffa
rolling jaffa's Avatar
My airbag light did the same thing.
I took it ford and they replaced the wiring harness for the side bags.
Nearly exactly 1 year later the same thing but this time it was the passenger airbag (not my side so it didn't matter so much).
So I'm expecting to go back one day to get the drivers side replaced.
Rod
rolling jaffa is offline   Reply With Quote Multi-Quote with this Post
