Old 13-09-2005, 07:01 PM   #1
FRIKA
FRIKA
FRIKA's Avatar
Unhappy Condensation In rear tail lights
I currently have condensation in my rear tail light. Anyone Know what the best thing to get rid of it is???? And dont say wipe it of with a cloth.
Are the tail lights eay to take off and put on????
New 2008 LV Focus XR5 in Performance Blue
FRIKA is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 07:12 PM   #2
MAD
Petro-sexual
MAD's Avatar
Dunno about geting them off, never done it, but I wouldnt imagine it being hard.
Obviously its got a leak somewhere, and all you have to do is plug it up.
I had water getting in my right rear indicator, all I did was glue up the leak and then drill a small hole at the bottom to let it drain off incase I didnt fix the leak properly.
You should be able to find an inconspicuous (spelling?) spot to drill a hole if required.
- The Story
Old 13-09-2005, 07:13 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
they are easy to take off,, pop the boot, undo the 2 phillips head screws, then inside the boot, pull thrim trimaway to find a 10mm nut that holds the corner in, then twist the bulb holders out of the sockets.. BINGO..
Shove a rag over a screwdriver or a drift insert it where the bulbs go. Wipe the inside of the lense, or compressed air is better if you have access to that.. It is a good idea to drill a tiny drain hole on the inside corner of the lense to let the water run out.. I have seen them full of dirt, full of water like a fish tank and even full of mould :(
Old 13-09-2005, 07:15 PM   #4
FRIKA
FRIKA
FRIKA's Avatar
cheers for that ill see how i go.
Old 13-09-2005, 08:24 PM   #5
GlennBA
GlennBA's Avatar
mine do the same, they always dry by themselves if i park the cark in the sun
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 09:20 PM   #6
FRIKA
FRIKA
FRIKA's Avatar
im just to padentic. Its obviously due to the weather. Im sure when it warms up it will go away.
