Custom User Title
Yeah, as the title suggests.
I've replaced the MAP sensor, but to no avail... The car runs fine, and goes fine (has troubles with stalling if you start it then let go of the accelerator, you have to hold it at about 1500rpm for a minute or so or it'll just stall, but once it's going it'll idle happily) All I can think of is a leak somewhere. I haven't noticed anything on my driveway, and losing 40 odd litres of fuel seems a bit accessive, surely it'd make a more apparent leak :\ Any ideas? As you can guess, i'm getting pretty fed up with buying $100+ of fuel each week. Thanks |
#2 | |||
did you check the plugs?
No Speed Limits on Fwys
might be a pressure leak from somewhere, only happens when the fuel is pumping, any leaks in or around the injectors anywhere....?
1996 EF 2 Fairmont
I like work, it fascinates me. I can sit and look at it for hours. ![]() |
The Mandarin Monster
I'd suggest you either have a massive flow problem with either the Injectors, considering it stalls (Im guessing as its flooding below 1500 rpm) or the fuel pump maybe?
www.unekefurniture.com ![]() ![]() ![]() ![]() Click here for the FPV and XR Club ACT Website |
GT
injector stuck open id say .or major ecu fault
#6 | |||
Custom User Title
they call me Tibbo
one or two bad injectors was what i was thinking of too
#8 | |||
Custom User Title
GT
you need to take it to a fuel injection specialist or ford.
thats only $70 something for the trip not bad...
car that goes (just) <----- gonna be MENACE so :thebirds: |
Sound like injectors to me too, MAP or oxygen sensor or a dead other sensor wouldnt stuff AFR's up quite that much.
Have you looked at all the plugs or just 1 ? Also do an ECU test
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
#12 | ||
Two > One
a dead MAP will cause this exact problem, however you replaced that so it seems to not be that.
Take your injectors out and get them ultrasonicaly cleaned.
Have you checked to see if you have manifold vaccum at the map sensor?
#14 | |||
Custom User Title
#15 | ||
check your fuel tank for holes!!! LOL, that's shocking!!! A stuffed sensor wouldn't throw it out that much. I'd be checking stuff like split hoses, leaky fuel filter connections, connections to the pressure reg....anywhere where the fuel flows through. Other than that it has to be the injectors. I've got some one ebay, work perfectly for 30 bux if your quick lol ;)
#16 | |||
#17 | |||
on the subject of coolant temp, is the car running at the correct temperature, if you had a thermostat which is jammed open (or removed), the computer could think the car is cold and be running way too rich. leaking injectors could be a problem, but you wouldn't expect all injectors to be leaking at the same time and if only 1 or 2 where leaking, only those plugs would be fouled. Have you checked for codes from the computer? |
#18 | ||
Custom User Title
Ok, just had a look at all the plugs.
#1 - split 50/50 red/black #2 - J red, electrode black #3 - won't come off #4 - fully black #5 - fully black #6 - fully black |
#19 | |||
Custom User Title
apart from those 20 or so seconds you have to hold the accelerator on to get it to idle, the car runs fine, no lack of power, and (as far as i can tell) isn't blowing too much black smoke. |
#20 | |||
Bad Music and Litre Bikes
You'd know if it was leaking fuel in your driveway or wherever you park it. I mean its not easy to miss 40Litres of fuel sitting on the garage floor, so it would have to be burning it off.
By the look of your plugs, cy 4, 5 & 6 is where your burning it off. They're running rich. Take your injectors out and get them ultrasonically cleaned and see how they come up. Thats all i can suggest, though im new to all this EFI stuff. If my XY was doing it, id pull out the screw driver and adjust the a/f mixture...
XY Wagon - NAKED! Quote:
#21 | ||
Did you check for vacuum at the map sensor?
#22 | ||
02/90 EA II Fairmont
someone hasn't been siphoning (sp?) it have they?
211RWKW EA |
#23 | ||
one question,,can you smell petrol any where around the car???
#24 | ||
Smile
Your problem is a faulty fuel regulator or blocked return lines to the fuel tank.I think that you have too high fuel pressure
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#25 | |||
Custom User Title
#26 | |||
![]() Join Date: Dec 2004
#27 | |||
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
#28 | |||
#29 | ||
Custom User Title
Hey, you guys bought AU's, it's not my fault, you guys live with it, just not in my thread.
#30 | |||
