Hi guys, Im mounting new 6*9 onn my rear shelf but theres only a small hole there. Whats the best way to cut out the 6*9 hole. Any ideas will be good otherwise i will stick with my original plan, use the "CHAINSAW"
THANKS BOYS ![]() ![]() ![]() |
XR6 and XR8 Club of QLD
If you modify your parcel shelf the car will be unroadworthy.
Easiest way is to buy some spacers from Autobarn / Supercheap etc which will lift the speakers up, then only the magnets will drop down through the hole. Panda
Car - Ford Falcon XR6 Turbo |
what he said
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds: |
#4 | |||
The one and only
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
no there not,,what a load of cobblers,,there perfectly ok and work well,,i've never had any problems with them and they sound good..
ORSM FORD CRUSIERS
the 6x9s are great it gives you decent bass without haveing to lug a massive sub box and amp around. alll u have to do make a fake parcel shelf with a piece of MDF and mount the 6x9s to that you can use the stock carpet over the MDF it easy.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
#7 | |||
The one and only
:hihi: 6x9's giving bass. Ha ha ha.
Never heard that before. They sound OK, but are don't serve a purpose. To run them effieciantly you need an amp, if you run an amp you might as well run a sub. If you run a sub you don't need 6x9's.
#9 | |||
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
well my car has the parcel shelf "modified"...guy got a roadworthy for it (i must find out his name if I sell my car..lol)
If you dont want a sub then 6x9's are awesome...mine suit my needs perfectly. im not wasting money on audio.... all speaker spacers ive seen look very ghey ![]()
#11 | |||
#12 | |||
If you dont want a sub go 7x10's now these are awesome .
DLS R1070 - 2-way coaxial 7" x 10" http://www.dls.se/images/highres/1070_F.jpg REFERENCE series R1070 is a 7" x 10" 2-way coaxial speaker with a 25 mm tiltable silk dome tweeter. Can be installed in the same mounting hole as a 6 x 9" speaker. separate filter box with only high class components. selectable tweeter level. Grilles are included. Best in test in the Brittish magazine Fast Car 2000. Was awarded with gold in the brittish magazine In Car as best 6 x 9" speaker in the Brittish market. I have these with a big amp no sub and they are dynamite. Unless you want serious Dush Dush Sh*t these have tonnes of BASS
--------------------------------------------- Last edited by The Mighty Red; 28-08-2005 at 08:59 PM. |
#14 | ||
ED Fairmont
I just got 6x9's a few days ago. If youve got three lap sash seatbelts then you can;t use spacers. The seatbelt retractor gets in the way.
Yes its true that if you modify the parcel shelf (metal bit) your car will become unreadworthy. I actually had a fake parcel shelf made underneathe the actual metal piece so that the speakers can be held in. Its about the only way to get them in with minimal modification. Remember this only applies if you have 3 lap sash seatbelts. If your going to get an amp you might as well get a sub. Which would mean that 6x9's are a waste of money. Get some good quality 6 inches and just run them on high pass through the amp. 6 x9 are no better than 6 inch speakers if your running on high pass. (means no bass coz the subs gonna do all the bass work for you.
![]() ![]() *Lowered with King Springs* *BF GT-P Rims* *Pacemaker Extractors* *2.5" High Flow Cat* *2.5" Straight through to the Tip* |
#15 | ||
Lovin the Manual.
just cut the shelf =P
if u have trouble getting a roady just go round to a few different joints use a jigsaw and cut the holes man! i cant stand the look of the 6x9 spacers from autobarn/supercheap |
#16 | |||
Low and Loud
Ive got 6x9's in my ea, i just made up some MDF spacers and fitted them under the parcel shelf carpet. I had to take some of the 6x9 holes out aswell but ive never had problems with RWC issues ![]()
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
#17 | ||
but that means the sound just hit the rear window.
#18 | |||
Low and Loud
Id rather have some sort of bass/midrange with them mounted flat in the parcel shelf then in a angled (that points at the roof anyway) plastic riser that just makes them glorified tweeters ![]()
#19 | ||
Ok, i prefere the way i have got it ,in boxes, i think it makes the sound clearer
#20 | ||
Mr Forty Seven
Personally I think raised speakers make the back of the car look ugly.
Which is why I got a sub, only problem with the sub is the boot rattle. You can't win, unless you pad the carp out of your boot ![]()
EFII Fairmont Ghia Fully Optioned In White XR Kit, Engine & Springs. Leather & Sunroof Also Featuring NFERNO Registration Plates ELXR Front Bar & Bonnet with Sequential Scoop 18x8 Graphite Rims, Genie Extractors and Exhaust, Chrome Moulds ELGT Steering Wheel, Clear Repeators, Cornering Lamps, Tinted Windows Walnut Highlights, Pionner DEH-P9650MP Headunit & Pro-Series Speakers Local Playground: Brisbane CBD and surrounding suburbs |
#21 | ||
Most RW testers will pass hacked up parcel shelves. I know mine passed. :P
#22 | |||
The one and only
If you run 6x9's of the HU they draw more power than the Hu can usually supply and this causes distorsion and you loose clarity. I still do not see any reason why anyone would fit them. I have 2 sets of 6x9's and 1 set of 7x10 sitting in my shed. They are good for magnets and that's about it.
#23 | ||
well my 6x9's make the louver rattle,,the old 6's never did.
#24 | ||
#25 | ||
*Smart *** comment here*
i found my solutuion lied an extremely good pair of 220w, 4 way 6" pioneer speakers... at the time they had the deepest 6" cone u could get, and they slotted rite into where the old 6's came out, followed that up by an amp and sub... the even better thing is everyone looks and wonders where the hell the noise is coming from when all they see is 6" speakers... probably cost u the same as a pair of 6x9's, dont need an amp, for the speakers, sub of course did, and puts most of my commo mates chapel st systems to shame! its loud as hell and still has potential! food for thought... anyways
#26 | |||
They are an excellent alternative to not having a sub with great BASS.
#27 | ||
The one and only
:evil_laug
That's right out all the car audio I'm yet to hear 6x9 or 7x10 keep up with subs. So I guess I have no idea. I'll eagerly await anyone to show me a set od 7x10's keep up. Anyone. I guess you turn up the BASS on the HU 'to get more out of it' too. ![]()
#28 | |||||||
Panda
#29 | ||
I said unless you want serious dush dush cr*p then these speakers will give you all the QUALITY bass you need.
My home theater has a very good sub running it and I would not be without it but for the car i personally do not need a F**kin great sub takin up space. Then again I suppose if i was 18 I guess i would. ![]()
--------------------------------------------- Last edited by The Mighty Red; 30-08-2005 at 09:01 AM. |
#30 | |||
Redhead extraordinaire...
Ok my two cents' worth.
Firstly, if ppl prefer 6x9s over subs then they are entitled to their opinion, LTDHO, therefore they DO serve a purpose. I had my system set up with 6.5 JBLs and then I switched to 6x9 Sonys and I can tell you that I prefer the 6x9s. Also they both were running with the sub. I can get more definition out of the the sonys. Secondly, you don't necessarily need an amp! Some head units have enough for the average user (not everyone is into performance audio nor do they have neverending pockets) and they are quite happy with "good enough" sound. Not everyone wants to doof up and down the main drag, drawing attention to the little peepee syndrome that seems to inhabit the bodies of boys turning into men. Thirdly, spacers are FINE. Gees, you guys are so obsessed with how something LOOKS! Gimme a break, as a chick I would prefer you had spacers and a decent engine than a crap engine running like shyte and pretty ricer stuff that makes your dick shrink. Fourthly, not everyone has space for subs. Some ppl on here have LPG tanks etc, and if they have kids, they need the space for things like prams/food shopping etc. And finally, the sound coming from the parcel shelf may reflect off the rear windscreen but you forget that some of the sound is echoed in the boot space, hence giving you a nicer rounded sound. Sound can reflect off the windscreen and into the rear compartment too. End of rant! ![]()
Bindi 88 EA- his car 88 Rolla - MY car Quote:
