Just putting a towbar on an ea wagon. Can anyone help on where I splice into the vehicle wiring and then run it??
Cheers Scruff |
Standerd or the ones with power brakes?
Just a standard 1600 kg trailboss.
windsor user
should be a plug in the loom near the drivers side tail lght.
i cant remember exactly where you find it though. i think you have to remove the drivers side rear load area plastic trim.. remove the drivers side tail light globe access pannel and feel around to see if you can find the spare plug |
Thanks fellas'
Just to finish this post off in case some ones does a search in the future. Couldn't find a plug but have a auto sparky as a mate and he just spliced into the main loom located behind the rear rhs indicator panel (cost a carton of xxxx). Thanks again. Scruff |
