The Guy You Love To Hate
Was chatting to the bloke at FTG Salvage today about IRS conversions.
Thought it may be of interest, he mentioned that someone came in and bought an IRS rear end from an AU and did a conversion into his ED. Apparently everything bolted in, only needed a space cut in the bottom of the boot to access hard to reach places for the cradle mounts when welding. |
windsor user
yep.....knew it already and the front end is fairly easy too aparently
gives AU offset too ![]() i'd do it if i could afford |
Last warning
FTG did it to an EB or ED XR8 from what i recall
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
I got quotes 1200 for the IRS unit then when I asked again ready to buy it went to 1750!
![]() Join Date: Dec 2004
Its not that hard, the AU used the same mounting points for the IRS and the live axle... which is very much the same deal as any E Series.
I can highly recommend it too. Yes its heavy but you can say goodbye to bump steer and the grip is superb!
Last warning
i want an AU live axle rear end and AU II kframe & brakes
![]() would suit me well!
#7 | |||
buy an AU then ![]() |
#8 | |||
Last warning
lol
ill have a beer milkshake
so the au front/subframe etc fits an ef?
current cars: 2001 AU SII XR6 manual 2001 Nissan Patrol 1969 Isuzu Florian 1976 Chev luv (really its just a rebadged Isuzu!) 1980 Isuzu KB 4x4 |
#10 | |||
windsor user
would love to try it |
Last warning
its not a straight bolt up, there are some mods to be done.
but apparently it *can* be done.
#12 | ||
anybody done it? and is the only benifit being able to use au/ba wheels, or are there other benifits?
Last warning
no one that we know has done it.
benefit = au/ba wheels & better brake upgrade options.
#14 | ||
PM me if you want
AU have an alloy k-frame so would be lighter as well I belive.
#15 | |||
they call me Tibbo
#16 | |||
He orginally raced an EB in offroad racing, he made his own suspension to suit (lengthened spindles, custom springs and shockers, big offroad tires etc) so when it came time that ford wanted him to upgrade to the AU instead of having to go and make everything again he simply just swapped it over. I've talked to him a fair bit about the conversion but not having any real knowledge about the 2 setup's it was hard to understand. He also beleived the steel k frame was a bit more durable. Looking at his photo's from the races I can say he would have wanted the strongest setup he could get! Quite a lot of his photo's involved the car being airborne and some of the stories he has told are quite amazing
#17 | ||
Does Steve have a car?
Awww man, i'd love to do this, only thing is i spent a sh!te load to get my current diff modified, meaning that would have all gone to waste :( Ahh well I might consider it when i run outta things to do :P
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
#18 | |||
#19 | ||
AU k-frame should bolt up pretty easy. As far as I can tell, you need to lengthen two studs, that's it, it uses the same mounting points. Upper arms bolt up, might have to use AU shocks. I was going to do it to fit the AU engine and AU2 brakes, but obviously that plan is over.
#20 | ||
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
So we need to engineer a turbo, but changing the complete suspension setup doesn't?
Seems like ALOT of stuffing around, surely a nice aftermarket kit (springs/shocks etc) could be done for much less than that and not be too far off.
#21 | ||
Oops, I slipped....
Rough price for an EL GT brake conversion is $1200, and theres only so much shocks/springs can do to overcome different suspension designs/angles.
I'm seriously thinking about doing the AUII front conversion, I need to replace the K-frame, change radius rods, some bushes, sway bars etc, so its not a bad idea. Does anyone have a few high-res pics from underneath an AUII? Do the PBR Cobra twin piston 330mm brakes bolt to the 298mm stock brake spindle, or are they different??
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#22 | ||
might try it on something too!
#23 | |||
they call me Tibbo
#24 | |||
windsor user
#25 | ||
Look in the technical section. Theres a detailed section on the AU suspension setup. Unsure is its AU1 or AU2.
#26 | |||
#27 | |||
And the stock AUII/III brakes were 287mm by the way.
AUIII Falcon Forte, with SIX Appeal |
#28 | ||
Oops, I slipped....
Cool, thanks for the info guys.
Will the brake booster/master cylinder need to be changed? Here's the article for the front susp. It is AUII http://www.fordforums.com.au/vbporta...article&id=158
