Old 20-08-2005, 11:17 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Starting Issues
Twice today I have had to attempt to start the car 3 times. Turn key, hold it, wont start. Turn back to acc, try again, wont start. Turn key right off, try again and it goes.
Just wondering if anyone else has experienced this?
Was a cold day but the car was by no means freezing, the plugs and leads are all around 10,000km old (had new ones put in before i picked it up) and there's no other signs of it running like crap etc etc. I'll be taking it back to the dealership but I think this may be one of those niggly little problems that only ever happens when there isnt service personnel around (i.e. when it can be fixed).
Also whil we're sort of on topic has anybody had experience with aftermarket ignition leads for Focus?
2024 F150 XLT
Old 20-08-2005, 11:43 PM   #2
whippet_zetec
Supes
whippet_zetec's Avatar
I think it is a safety mechanism for the Foci that it wont allow you to go stright from accesrories after a non-start to ignition on again.....
same thing happens to me if my Foci doesnt start first time...have to go all the way back to off position and then return to ignition on.
dont stress about it if its a once off.....start to worry when you have to try turning your Foci over a few times before it starts.
Yes I DO drive a Toyota
whippet_zetec is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2005, 11:47 PM   #3
zetec
Zoom Zoom
zetec's Avatar
not good to hear. melbzetec has magnecor ignition leads on his car i believe. They're definitely aftermarket.
2012 Mazda3 MPS
Old 21-08-2005, 12:01 AM   #4
b2tf
b2tf's Avatar
Yeah, i wouldnt be asking if it was a rare occurence but it has done it twice today and at least 5 times before that.
And when you're parked in the Main St with the bogans going past in their Commos and your shiny clean car isnt starting, its not a good feeling!
2024 F150 XLT
Old 21-08-2005, 08:20 AM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
Yeh I have Magnecor silicon ignition leads. Never had a single problem with them. Never missed a beat. I can't say they make any performance difference. It's just a thing I do........I always replace those serviceable items that car companies can save a few bucks on in manufacture, by putting in premium items. eg leads, air filters, spark plugs.etc. I just think it makes everything run that bit sweeter
Old 21-08-2005, 08:41 AM   #6
Laminge
Cuban... nothing like it
Are the keys coded?
Have you tried the spare?
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2005, 10:11 AM   #7
b2tf
b2tf's Avatar
Thats exactly what I think too.
Gary, Ive never used the spare yet and its hard to make it do it. Will only fail if Im parked in a busy spot with lots of people around, or so it seems.
2024 F150 XLT
Old 21-08-2005, 11:33 AM   #8
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
My '03 Foci has just under 25K on the odometer and has the same problem. Including the automatic choke not operating on start up but when you select reverse it operates but only for a very short time. I've had the E.C.U. re-programmed twice now and the same problems with un-even revs whilst you're driving occuring, which makes me think there is a software problem with the electronic throttle. Are there any T.S.B.'s that can fix these problems??
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2005, 06:52 PM   #9
whippet_zetec
Supes
maybe its an auto issue? I have a manual zetec and cant say I find any ignition problems.
Old 21-08-2005, 07:35 PM   #10
b2tf
b2tf's Avatar
Possibly but I dont quite see how the transmission could affect the starting of the car?
2024 F150 XLT
Old 21-08-2005, 11:12 PM   #11
zetec
Zoom Zoom
zetec's Avatar
Electronic throttle? It's a mechanical cable throttle on the LR Focus. What did you mean? (Hello by the way mate!!! :voldar02: )
2012 Mazda3 MPS
Old 22-08-2005, 07:21 AM   #12
KJGH
G6E Driver
Both our manual and auto do it. Seems to occur more when our cars have already been used for the day.
:hihi: NOW: 2008 FG Ford G6E
:hihi: WAS: 2007 LS Ford Focus XR5 Turbo
KJGH is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 08:40 AM   #13
Racecraft
they call me Tibbo
Racecraft's Avatar
on that issue, does the car start without the clutch depressed on the manual cars? I know my oldies Hydaggy must have the clutch depressed fully reguardless of the gear postion. Is the Foci the same?
Back onto your trauma, It could be an ecu to inhibitor switch issue?
I have had similiar issues on two of my BA's.. One it turned out as Minge touched on, was an issue with the programmable key, the other was a royal butt muncher, there was a stretched wire in the loom that went to the cluster. It was so tight in the harness that it was beginning to pull the pin out of the loom plug. Very intermittant but the frequency increased but 2 days later and a $600 auto elec bill we isolated the wire causing the problem..
Old 22-08-2005, 09:21 AM   #14
whippet_zetec
Supes
nope, manual Foci does not require the clutch pedal to be depressed to start (although alot more cars these days are now incorporating such).
Old 22-08-2005, 10:17 AM   #15
b2tf
b2tf's Avatar
Same with me, on Saturday it was after a half hours driving then about 1hr parked.
I'll go see what I can find out today, hopefully there'll be a TSB for it if its common.
2024 F150 XLT
Old 22-08-2005, 01:31 PM   #16
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Hi Zetec,
Hope all is well.
Oh, a manual cable throttle! Someone's given me a b**-steer.
Old 22-08-2005, 06:29 PM   #17
zetec
Zoom Zoom
zetec's Avatar
...easily bypassed too!!!!! Pain in the ****, what if your clutch jams, I think it's silly (despite I'm sure some safety reasons or something) to limit your ability and theoretically increase the chance of something going wrong by adding yet another mechanism... :gren:
2012 Mazda3 MPS
Old 04-09-2005, 10:56 PM   #18
ja-ja-binks
i recently bought a 2003 lx sedan 2.0 auto and i have noticed the same problem , (thats how i found this forum) it has happened to me after driving home from work (100km 0 twice now when i try to restart car within about 20min to 1/2 hr. my car was parked on sloping driveway ( uphill) not in flat garage. could that have something to do with it?
ja-ja-binks is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 08:40 AM   #19
whippet_zetec
Supes
has anyone actually had a Ford technician look at this problem yet and was there any offical response as to why it occurs?
Old 05-09-2005, 09:57 AM   #20
b2tf
b2tf's Avatar
There is a TSB available for it - TSB 69/03 is done to fix this problem and it's basically a flash update deivered via WDS. Im yet to have it done but will be in the near future (just have to find the time to drop the car off).
For anybody who is having this problem, quote that TSB number when asking them to fix it, and ask them to see if your car is suitable for it.
2024 F150 XLT
Old 05-09-2005, 12:05 PM   #21
WASACL
Phat-Euro
WASACL's Avatar
Hey... Yours in auto isnt it... Maybe it is something wrong with the Park selection??? Tried starting it for Neutral?
Russ
Wake up and smell the FOCUS!
WASACL is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 02:27 PM   #22
b2tf
b2tf's Avatar
Russ
Russ,
yeah its an auto but its not the gear selection etc that does it.
2024 F150 XLT
