Go Back   Australian Ford Forums > General Topics > Ford Forums Central > Site Support
Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here.
Old 20-01-2005, 10:42 AM   #1
RATT
Default Page loading up blank?
This is happening on my home PC. The page loads (according to bar on the bottom right) which then shows us "done" but the page stays blank. :
I first thought it was only FF.au but it also happens to other forums so it's obviously my PC that's the problem.
I have various anti-virus, webwasher and spyware programs to protect it but it is still happening.
Any ideas as to what could be causing this?
Old 20-01-2005, 10:56 AM   #2
3Toed
The Smoking Sloth™
3Toed's Avatar
Try deleting your Internet Explorer history and tempoaryinternet files. Maybe even your cookies.
With your AV and anti-Spyware softare, make sure they are fully up to date. Also, have a look for some other anti-Spyware utilities. I run Ad-Aware and SpyWare Doctor. Both find stuff the other missed. And some other stuff I have to remove by hand because none of them would find it.
Originally Posted by Sloth
Filthy cars are awesome.
Amen Brother.
3Toed is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 11:06 AM   #3
RED_EL_XR8
RED_EL_XR8's Avatar
Another thing you can try is going to tools/internet options/security tab
and set the internet zone back to default.
IE is so insecure, and heaven only knows what scripts etc can get in and mess with your settings.
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 11:35 AM   #4
rag top
rag top's Avatar
I get the same problem, but it only happens occasionally and only with google.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 11:43 AM   #5
RATT
Thanks for your help guys. I'll give it a go but keep the suggestions coming.
Old 20-01-2005, 12:33 PM   #6
Laminge
Cuban... nothing like it
Delete Cache, Cookies and temp files
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 03:02 PM   #7
XA-Coupe
format computer, load a different OS.. change brand of RAM... recondition the mouse and throw away the mouse pad
XA-Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 06:55 PM   #8
RATT
Thanks slothy. How do you remove spyware/adware by hand?
Old 20-01-2005, 08:50 PM   #9
3Toed
The Smoking Sloth™
3Toed's Avatar
It can be tricky. You need to know what to look for.
First thing you need to find out is the name of the executable that is running and causing the problems.
Start the registry editor (Start->Run type in regedit and click OK) and explore down to HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Run. Then on the right hand side look for thing that you don't recognise. You'll have stuff in there to launch any chat clients and any other things that start automatically. Look for one you don't recognise.
If you do find anything you don't recognise make a note of the executable name and then delete the entry for that executable.
Then go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run and do the same.
* Be careful, editing your registry can have nasty consequences if you edit or delete the wrong thing. Any actions are immediate and there is no Undo option.
Now fire up Task Manager (right click on your task bar and choose Task Manager), click on the Processes tab and turn on the Show process for all users check box.
Now look through the list for any process with the name as what you found in the registry. If you find it (and there may be more than one running), right click on it and choose End Process, and click OK to confirm. Do this for instances of the process.
Now, open Windows Explorer and right click on your C: drive and choose Search. Then in the filename field type in the name of the executable and start the search. When it finds them, delete them. If you get an access denied it probably means it's still running so check Task Manager again.
Reboot and do the all of the above again. I've found the sneakier ones have some method of coming back after a reboot. One even had 3 or 4 different executables in various locations all looking out for each other. It was a bitch to get rid of and took me over half a day.
Two chicks at work got major spyware on their personal lappies and after trying the manual method it was decided a nice clean reformat was in order. That might be your last resort. :-(
Good luck!
Amen Brother.
Old 20-01-2005, 08:59 PM   #10
svo347
AFF's 1st DM.......
svo347's Avatar
Also try re typing your homepage into the homepage box., under tools internet options.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
