Hurry up Germany!!
hey guys,
i was thinking recently if it would be worth keeping my EBII, in a couple years (im 18 now), and keep on working on it or get rid of it. i decided to keep it as i cant imagine getting rid of it in two years!!! anyway i was thinking of what to do engine wise and with the help of Stu (dogbreath_48) we came up with the idea to eventually drop an EL or hopefully even an AU xr6 motor in and do some mild work to that. how much roughly would each of these motors cost to put in? should i save my money now by leaving my EBII motor standard and save money for the newer engine later on? one reason i want to do this is my EB has done about 280k's, so a newer engine i thought would be the better option for the long run. any thoughts? cheers Daniel
2009 WS Fiesta Zetec 5-Door
Color: Vision |
well unless your motor is stuffed just leave it. spend the money on a manual for best performance then go a cam and extractors.
#3 | ||||
I'd suspect an AU motor would be alot of trouble, given the different plenum/intake and computer. Would i be right? |
Last warning
if u were gunna use an AU engine, u'd use the block and head.. and have to stuff around with the belt system, thus use XH bits and peices to keep the EB manifold.
or you could use the AU belt system, and AU manifold etc.. (extra work) finding low KM ef/el engines will be getting harder now.. plenty of AU low km engines..
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#5 | |||
#6 | |||
exactly - clean up the block and head and throw some new bearings and rings in. Will probably cost the same but youll have a new engine.
#7 | |||
But i see your point. |
Turbo Dinosaur FTMFW
you're all soft lol.
my ebII has an AU2 6cyl in it. easy job. well, now that we've figured it out its easy lol. 36000km au engine with all ancilleries cost me $1200. can be had cheaper now. we used an EL BBm and EL ECU. a few extra wires, but nothing major. not only does it operate the BBM vacuum swith but it also switchs the EF thermo fans. with the BBM you can then fit an EF/L airbox + tickford snorkel. you have to shave a bit of the ribbing off the front of the sump (nothing major) and its best to use an au bellhousing (mine cost $50) i only fitted mine because i killed the eb engine. as in cooked it. if you can get one from a wrecker with a warranty, its not a bad idea. i wouldnt bother retrofitting eb v-belts though. and you can still run an EB-D manifold on the AU motor, so that can make it a real easy swap. after saying all that, an au motor is essentially an EB motor, still just a 4.0L six, fits in the same spot. just a tad stronger.... like i said, i killed my eb motor, and i figured the cheapest/best option was AU. its a good selling point too ;) as the others have said, depends on whats wrong with your motor. if its fine, just not powerfull enough for you, cam and exhaust it, then go manual ;) |
Hurry up Germany!!
yer ok thanks guys
it is running fine but this whole 'new engine' thing wouldnt happen till another few years when i get some money to really spend on her. in a few years she will probably be around 300k's. yer im going to go air intake and extractors and see how she improves in performance. thanks for the advice guys
Color: Vision |
