Go Back   Australian Ford Forums > General Topics > Ford Forums Central > Site Support
Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here.
Old 30-06-2005, 05:24 PM   #1
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Default Attachments
Is it possible to attach a picture to a second post? I am getting an error message, and even a copy of the file won’t attach.
Thanks
Old 30-06-2005, 09:15 PM   #2
Laminge
Cuban... nothing like it
you can attach upto 10 images per post
Whats the error message mate?
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2005, 09:51 PM   #3
outback_ute
Ute Forum Moderator
Contributing Member
No, I wanted to attach an image I had already used in another thread. I couldn't see any way to access or reference attached images already in use so I tried to upload it again.
This is what it says:
Upload Errors
Fog2.jpg:
You have already attached this file in thread : Driving Lights
Old 01-07-2005, 02:21 PM   #4
Laminge
go into your user CP section
Down the bottom of the right of the screen there is an attachments options
Click on that, and that will allow you to delete attachements
Or...
Just rename the file you are trying to upload
Old 01-07-2005, 02:30 PM   #5
outback_ute
Ute Forum Moderator
Contributing Member
Thanks for taking the time to look into this Gary. I did try renaming the file, and also tried making a copy of the file but it still "rejected" it. In the end I cropped it slightly and it worked. I think it probably worked if I had saved it with a different compression level etc too, just a change of the file physical (electronic???) properties.
Old 01-07-2005, 02:35 PM   #6
Laminge
Bugger me
I didnt realise it filtered files to that degree.,
Good point for the future though when wanting to attaching the same image twice in to threads, make sure its a different size and name
