Old 10-06-2005, 07:00 PM   #1
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Default Transmission Modification
Hi,
I just thought I would see if anyone on this forum knows how to modify the AU transmission using resistors. A gentleman was going to help me, but I think he has been waylaid.
I have10 x 5 watt 33 ohm resistors (I think I need three) and I believe they are meant to go somewhere on the wiring for the trans. I just dont know where.
I looked at the mod on the AU falcon site, but it uses different resistors.
I have to drive to Sydney on Sunday and back on Monday I just want to give the trans an easier time.
Can anyone help me???
Roy
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2005, 09:10 PM   #2
xr8 007
xr8 007's Avatar
what is it meant 2 do??
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2005, 01:24 PM   #3
Dauphin
Irregular member
Dauphin's Avatar
I think there are some circuit / wiring diagrams uploaded by Russel somewhere on this website.
Old 11-06-2005, 01:44 PM   #4
Casper
Contributing Member
Casper's Avatar
Theres an article by Useless in the workshop section of aufalcon.com too.
Older, wiser, poorer.
Old 11-06-2005, 03:22 PM   #5
jonbays
TL40 Wagon?
33 Ohm 5 watt are no good mate.
theres lots of different combinations you could try but not 33 ohm unless you parallel a few which will get you close to the correct resitance and power rating.
You need 10 watt or two 5 watt resitsors in parallel for a start.
You should get a SPDT switch 10 amp 12v to turn on and off.
Find Pin 81 on your ecu (take it out) and trace this wire back in the loom under the glove box and cut it. Connect the ecu side to the centre of your switch. Also connect the centre to a 5.6 Ohm 10 watt resistor (or two 10 ohm 5 watters in parallel). Connect the other side of the resistor to the transmission side of the pin 81 wire and also to the off contact of you switch.
Now splice into pin 71 and run a wire to the on contact of your switch with an 18 Ohm 10 watt resistor in series ( here you could use your two 33 ohm 5 watters in parallel which are close enough).
Good Luck. It does all work but you may want to experiment with the values or build an adjustable one like useless has posted up in AUfalcon.com
Old 11-06-2005, 07:37 PM   #6
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
The mod is meant to assist the trans in dealing with more power and positive manifold pressure.
Thanks for the tips.
EA Turbo Ghia was suggesting the mod using the 5 watt 33 ohm resistors. I have been trying to PM him but his PM box is showing as full.
Is it possible he is using a different mod? Has anyone heard of such a mod? I think Dansedgli also did this mod? anyone???
Or am I better of just doing the mod as described above by jonbays???
Roy
Old 21-06-2005, 06:43 PM   #7
The Mighty Red
The Mighty Red's Avatar
Can anyone tell me if there is an adjustable shift kit that i can buy ready to install and then just give it to a auto electrician to fit.
I have read the article by Useless and as easy and well explained as it is i just dont trust myself to go messing around with the ecu.
I did read somewhere awhile back that you can buy a kit with an adjustable knob that you can adjust from a soft change to a hard change that will chirp the wheels if so desired.
Thanks in advance Gary
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2005, 06:48 PM   #8
Stav
Smile
Stav's Avatar
pm me for advice.See the site aufalcon .com...I wrote the article using real life experiences.
Old 21-06-2005, 07:21 PM   #9
dansedgli
dansedgli's Avatar
Give me 2 seconds and Ill post the wiring diagram. This mod is more suited to cars with more power than the other shift kit everyone else has.
It is very harsh but stops all slipping.
I tried the other kits you guys mentioned and it would still slip bad on gearchanges when on boost.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2005, 07:23 PM   #10
dansedgli
dansedgli's Avatar
Here is the one I used and it was great. Chirped 3rd Ea turbo ghia posted in on the old forums a year or so ago.
Im not sure if the au uses the same wiring as my EB though.
Old 21-06-2005, 08:50 PM   #11
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Thanks heaps. I have printed the diagram and will get the whole thing explained to me.
BTW whats DPDT? Can you give me a soldiers 5 on how it works?
Thanks,
Roy
Old 21-06-2005, 08:52 PM   #12
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Any one know if this wiring is a goer on the AU?
Old 21-06-2005, 08:52 PM   #13
dansedgli
dansedgli's Avatar
its just a type of switch, ask your local dicksmith/jaycar and they get one for you. Double pole double throw I think.
Old 21-06-2005, 08:54 PM   #14
Stav
Smile
Stav's Avatar
Dont use that on the AU .The resistances a re different on the AU
pin 81 on au ecu
Old 21-06-2005, 08:55 PM   #15
dansedgli
dansedgli's Avatar
Its a different type of shift kit to yours Useless. This one bypasses the S5 solonoid allowing the trans to run higher line pressure than if the S5 was electronically adjusted.
Old 21-06-2005, 08:57 PM   #16
Stav
Smile
Stav's Avatar
My one increases line pressure on s5 solenoid as if the solenoid was adjusted too.?
By passing s5 went to limp home.
Old 21-06-2005, 08:58 PM   #17
dansedgli
dansedgli's Avatar
This one bypasses the S5 completely.
My trans was fine with the above kit and so are many other E series. Not sure on the AU though.
At least its reversable if it doesnt work.
Old 21-06-2005, 09:00 PM   #18
Stav
Smile
Stav's Avatar
you are scaring me. :
Old 21-06-2005, 09:08 PM   #19
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Your scared?
Its My trans!
Is there any chance it will damage the trans if it does not work?
Old 21-06-2005, 09:13 PM   #20
Stav
Smile
Stav's Avatar
I have never tried the kit that dan has the design for .I have tried mine so am not familiar with the other design.If you chose my unit I can help out if you chose the other dan may know better.
Old 21-06-2005, 09:33 PM   #21
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
I am happy to try what ever will give me a definite shift under boost. At this stage I have to back off left it shift and bring it back onto boost.
Old 22-06-2005, 12:17 AM   #22
dansedgli
dansedgli's Avatar
The shift kit I posted can just be turned off if you dont like it. It will definatley improve your shift if it is now slipping under boost on gearchanges.
I had mine on for over 6months on a 300,000+ trans running 200rwkw and 10psi without a trans problem. I wasnt even running a trans cooler even though I should have been.
