Old 09-04-2024, 08:09 AM   #1
malbaby
Default Windsor 302 Cylinder Heads.
Hi Guys.....On the older engines, I am interested to know the difference in compression ratio of the closed chamber compared with the open design.
There is obviously a diffence in chamber volume.
malbaby is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2024, 05:31 PM   #2
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
Default Re: Windsor 302 Cylinder Heads.
Hi the,
two links to get you on your way
1. Compression ratio calculator. http://www.wallaceracing.com/cr_test2.php
2. Ford cylinder head data heaps of them. https://www.enginelabs.com/engine-te...sting-numbers/
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2024, 09:08 AM   #3
malbaby
Thanks for the reply....very informative, unfortunately no mention of horsepower.
Old 16-04-2024, 06:12 PM   #4
jpd80
jpd80's Avatar
That because many of the Windsor heads don’t make much power unless heavily ported
and then you risk hitting either oil or water…
David Vizard has done quite a few videos on porting SBC and SBF.
Years ago, he ported a 289 and got phenomenal power out of the thing
Link here to start you
https://www.youtube.com/watch?v=ttGQjpyAH1M
Most people now go aftermarket with either AFR or TFS Twisted Wedge (beautiful) as they
Unlock a ton of power in the Windsors. One of the agonies of a 347 is the amount you have
to spend just to equal what a GM LS 5.3 truck motor can put out with just a cam and good headers.
Old 16-04-2024, 08:02 PM   #5
ivorya
Mad Scientist!
ivorya's Avatar
https://www.youtube.com/watch?v=RsxV4LZWlJc
I love watching the vids from these guys. The parts are listed as well.
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2024, 05:28 AM   #6
PooDog
PooDog's Avatar
David Vizard is one of those real old school been there done that guy .....has some really interesting books and on YT
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2024, 05:34 AM   #7
PooDog
PooDog's Avatar
Google T Moss head porting , he has quite a bit of info in locating water jackets and where to port for home DIY , on mainly E7TE, GT40 , and P heads
524nm torque
Old 17-04-2024, 09:19 PM   #8
jpd80
jpd80's Avatar
Yes, Tom Moss did a lot of good research work on those heads, I followed his guidelines,
Porting some GT40P heads for my 302, milled them 0.30” and got a nice bump in compression
in my EB, feels nice in a mildly modified 5.0 but if you’re chasing really good power, those
TFS 11R twisted wedge heads are almost essential if you’re gong 347 stroker route…
Many guys on here have experience with them and can attest to the performance.
Old 18-04-2024, 12:04 PM   #9
PooDog
PooDog's Avatar
Did similar to the Gt40p,s on my AU ,CC,d the chambers too they work quite good alongside a decent cam
524nm torque
