Old 25-04-2022, 09:39 AM   #1
Grahamw
Default 2014 Ford Focus Wiring
I am trying to install power for a dashboard GPS by using a blade fuse double adaptor but I cannot get it to fit into the fuse holder. Has anyone had this problem and if so how did you resolve it? Is there a better place to patch into the power? I have tried filing down the plastic around the prongs but no luck.
Thanks
Grahamw is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2022, 07:54 PM   #2
stefcio007
Default Re: 2014 Ford Focus Wiring
Yes there are some spots you can use where it will fit. I had constant 12V and ignition wired to may dashcam use fuse taps.
https://fusecheck.com/ford/ford-focu...8-fuse-diagram
Check fuses when ignition is off and on to get your two sources.
Check ones that you aren’t using for example: I wasn’t using moonroof so checked that. For when I needed power in the boot I tapped off the heated seats fuse as I didn’t have heated seats.
A multimeter is your friend.
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2022, 09:20 PM   #3
Grahamw
Thanks very much for the info and the fuse info especially. I have a multimeter and as you say, good friend.
