25-03-2022, 07:27 PM | #1 | ||
Hi all
Front right ABS wire to the hub had rubbed thru the insulation and broken the wire Both the ABS and ESP lights are on - faulty wire so they should be on I've repaired the wire with a 400mm section from a wrecker car - Soldered joints - insulated and heat shrink over the soldered connection area The ABS and ESP lights are still on after the repair I've plugged in an OBDII scanner to check / clear the code - there are none Question 1 Will it show on OBDII scanners or is another scanner required Question 2 Will it go away (reset itself) after xx amount of starts I've pulled the ABS fuse and relay and started the car (not driven anywhere) turned it off - plugged them back in - lights still on On a road test (60-KPH) and standing on the brake pedal it pulls up with no shudder on the pedal and it doesn't lock a wheel - so assuming ABS is working There is a about 50 words in the owner's handbook about ESP It says SET/RESET - not sure if this will fix it or not Having trouble getting into the Main Menu to then progress to this option Last edited by rodo; 25-03-2022 at 07:37 PM. |
28-03-2022, 01:18 PM | #2 | ||
You probably need a ODBII scanner that can access the ABS system to reset the code the cheap ones don't , if you download Forscan and have a compatible adapter you should be able to view and if required reset the codes , is a free program
https://forscan.org |
10-05-2022, 06:23 PM | #3 | ||
Just to finish off this thread
I was having the Aircon regassed and asked if he had a scanner Came up with wheel sensor error RHF wheel Replaced the wheel sensor - Drove it 20 meters out our driveway Dash ABS and ESP lights went out - Error code did not need to be cleared |
