Old 25-09-2021, 08:23 PM   #1
Ben
Ben's Avatar
Default Au irs lsd rebuild/upgrade
Looking at getting my manual AU2 XR8 IRS Diff rebuilt with 3.91 gears.
Understand I will need to correct the speedo with a electronic corrector looking the most likely. Is this best picked up from behind the dash then I could mount the corrector up in the drivers fuse box access panel so I can access it if needed?
Onto the gears looking at the dana spicer 3.91 and get the shop to shim to fit.
Is there anything else I should be looking at for the diff while they are doing it or just a rebuild with the new gears?
End goals for the car are around 350rwhp.
2001 AU2 220 XR8 - Build thread
Ben is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2021, 07:19 AM   #2
sgj66
Default Re: Au irs lsd rebuild/upgrade
I had to replace most of the knuckle ? joints in my old man's ts50 in the car if you've got it out check every connection and if it looks the slightest bit dodgy replace it there is a rebuild of an irs in the t series page don't know the link but I found it really helpful
sgj66 is offline   Reply With Quote Multi-Quote with this Post
