Hi All
I just purchased a Uniden Dash View 30R dashcam. I am in the process of installing the hardwiring kit that came with the camera. The camera has both Acc & permanent 12v wires with mini fuse adaptors that need to be connected. What fuses in the cabin can I remove to plug these in? The hardwiring kit is different to the ones that come up in searches when seeing what others have done so any help from someone that has installed one of these would be much appreciated. I don't really want to tap into wiring so prefer to use the kit as supplied, there are no spare fuse locations avail Many thanks Peter |
Got a link for the product details or a picture to show what you're working with?
It sounds like you might want to use a 'fuse tap' that allows you to draw a new circuit from an already populated fuse location, like this: https://www.repco.com.au/en/globes-b...8bl/p/A9472649 |
Thanks, yes that's what I ended up doing.
All working now Sent from my Nokia 7.2 using Tapatalk |
